bearings which would be better to use
hmmmnz
PostPosted: 15:29 - 26 Sep 2007    Post subject: bearings which would be better to use Reply with quote
hi guys im currently doing a single sided conversion on my zxr, obvisously i need to do a bit of bodging, but my question is on a swing arm pivot inside the swing arm what bearings should i use, a sealed roller or a sealed ball, i can get both in the size i require,
what would you use??
cheers
hmmmnz
the humans are dead
I kick arse for the lord
PostPosted: 15:40 - 26 Sep 2007    Post subject: Reply with quote
I would have said rollers are best for a low movement, high load aplication. Spreads the load more.
hmmmnz
PostPosted: 15:47 - 26 Sep 2007    Post subject: Reply with quote
cool, i was thinking that,
your a gent stinkwheel Very Happy
the humans are dead
Odie
PostPosted: 19:14 - 26 Sep 2007    Post subject: Reply with quote
Neither, hardtail it. Thumbs Up Mr. Green
ZRX61
Victor Meldrew
PostPosted: 21:21 - 26 Sep 2007    Post subject: Re: bearings which would be better to use Reply with quote
hmmmnz wrote:
obvisously i need to do a bit of bodging, hmmmnz
Why?
PostPosted: 22:18 - 26 Sep 2007    Post subject: Reply with quote
Hows this for an idea. If you use two sealed bearings, prise out one seal on each then fit them with the open side facing in. Fill the space between them with grease.
hmmmnz
PostPosted: 23:12 - 26 Sep 2007    Post subject: Re: bearings which would be better to use Reply with quote
ZRX61 wrote:
Why?
why do you think???
im using a swing arm from a completly different bike with different size pivot bolt and different size bearings
the humans are dead
hmmmnz
PostPosted: 23:16 - 26 Sep 2007    Post subject: Reply with quote
thats not a bad idea, due to the space available, ive gone with a sealed roller on one side and a sealed ball on the other,
i was going to use rollers on both sides but there was a ball on one side any way, i guess as thats the part that has pressure against it,
the humans are dead
Big Pete
PostPosted: 12:50 - 28 Sep 2007    Post subject: Reply with quote
That isnt bodgery,using a bearing set is a conversion. Using a stack of greased washers would be bodgery.
Trust me, I`m an engineer
GarageOfPower.co.uk
hmmmnz
PostPosted: 13:02 - 28 Sep 2007    Post subject: Reply with quote
true enough, but i like the word bodging, i think it implies that i don't know what im doing Very Happy
the humans are dead
The last post was made 18 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 66.36 Kb
