Updating BIOS Help!? 1440x900 resolution problem....
JGY6000
PostPosted: 13:41 - 27 Sep 2007    Post subject: Updating BIOS Help!? 1440x900 resolution problem.... Reply with quote
Hi,
iv just bought a new 19" widescreen LCD monitor, and i had a few problems with the resolution, so i downloaded the latest driver for the grafix card (SIS 611FX) and it helped but i still cant get the 1440x900 resolution its meant to be. on the SIS website it says i should also update the BIOS version, which i am trying to do now, but i cant seem to work out what to download
Its an American Megatrends Inc, so i downloaded the motherboard finder software from their site and this is what comes up
AMIBIOS Motherboard Manufacturer Identification
Version 1.4 (01/12/2004) Copyright 2003 American Megatrends, Inc.
This file has recorded information useful in identifying the manufacturer
of this motherboard. The information is listed below:
ALERT: This BIOS has been identified as NEC BIOS!
Please contact NEC for motherboard support ... https://www.nec.com
NO STANDARD AMIBIOS IDENTIFICATION STRING DETECTED. PLEASE DO NOT CONTACT AMI TECH SUPPORT CONCERNING THIS PRODUCT.
For more information on upgrading your BIOS go to https://www.ami.com/support/bios.cfm?refer=mbid
SMBIOS info:
Manufacturer :
Product Name : P4S61
Version : 1.0
Serial Number: 00000000
but when i go to NEC site i can find anything with regards to updating the bios!?
swaffs
PostPosted: 15:44 - 27 Sep 2007    Post subject: Reply with quote
If this is XP:
Does your system know what monitor is connected?
In the display settings does it say
Display
(Default monitor)
xxx resolution
Try downloading the INF file for that monitor. (from the manufacturers site)
If it's still not allowing it, turn off the “Hide modes that this monitor cannot display” checkbox (under the adapter/advanced tab).
You will then be able to select any display mode , even if windows thinks it is incorrect for that monitor. Be carefull of selecting rediculous settings though, and if the screen goes weird, just wait for it to come back again (about 20 seconds) (or press ESC)
Be very carefull with that, and if you select a mode that screws everything up, you may need to reboot and push F8 to go into VGA mode.
Don't forget to run some colour profiling as well so your colours are true. at least load the colour profile that comes with the monitor.
Swaffs
Swaffs Photography |
BCF vinyl stickers
"Look not back in anger, nor forward in fear, but around you in awareness."
JGY6000
PostPosted: 16:48 - 27 Sep 2007    Post subject: Reply with quote
i have installed the monitor driver, and it is showing up under the display setting, i get a lot off different resolutions all the way up to 2048x1536, just not 1440x900, i even get 1400x1050, just not 1440x900, atm im using 1152x864 which is the best out of themm but the screen is a little streched
Hide modes that this monitor cannot display is unchecked so i dunno..?
willi
PostPosted: 23:10 - 27 Sep 2007    Post subject: Reply with quote
i find that 1024 x 768 pixels is better on my 19"
1440x900 just makes everything to small.
also check out microsoft update there will probably be an update for your screen there aswell under custom.
wat goes around comes around.
DEN MONKEY
PostPosted: 07:58 - 28 Sep 2007    Post subject: Reply with quote
The story goes that lcd monitors give a crisper picture at their native resolution though.
So its best to try and have it matched to the res setting on your graphics card.
I just put a new system together for my father and when I tested a relatively cheap graphics card I got for him on an old crt monitor it did not offer resolution upto the required level.
Upon connecting it to the lcd monitor with the dvi connection I was then offered the increased res.
So make sure you're not using the old analogue vga connection instead ( blue one ) this may be your issue.
A quick google also suggests ensuring your video card drivers are up to date and using the control panel from the card software instead of the usual interface offered by windows.
google 1440 x 900 lcd resolution and you will be face with a bit of reading.
Good luck Thumbs Up
meh
Glen
PostPosted: 16:08 - 28 Sep 2007    Post subject: Reply with quote
Had the same problem with my 20" LG, my old graphics card wouldn't display 1680 x 1050 so in the end I had to give up and install a new card. Annoying but it was due for an upgrade anyway!
leeves
PostPosted: 18:38 - 28 Sep 2007    Post subject: Reply with quote
i dont know what the problem is but i really dont recomend trying to update your bios you have to get the exact version and if you dont then you can say bye bye motherboard so i would leave that well alone. What moniter do you have?
>> Honda VFR750 [1995]
>> Honda CBR 600 [1996]
JGY6000
PostPosted: 20:09 - 28 Sep 2007    Post subject: Reply with quote
Its a Philips 190WV7CS 19" TFT Widescreen Monitor 1440x900.
The problem i am having is that i cant set the screen resoulution to 1440x900, that exact setting is not available, its not like my grafix wont alow it ( it goes much higher) its just that setting is no appearing as an option?
Its a SIS 611FX, iv installed the monitor drivers, i have the latest grafix card drivers, and on the SIS website it says if the new driver for the grafix card dont work make sure your bois is up to date?
The last post was made 18 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 60.43 Kb
