| JGY6000 |
 JGY6000 Trackday Trickster
 Posted: 13:41 - 27 Sep 2007 Post subject: Updating BIOS Help!? 1440x900 resolution problem.... |
Hi,
iv just bought a new 19" widescreen LCD monitor, and i had a few problems with the resolution, so i downloaded the latest driver for the grafix card (SIS 611FX) and it helped but i still cant get the 1440x900 resolution its meant to be. on the SIS website it says i should also update the BIOS version, which i am trying to do now, but i cant seem to work out what to download
Its an American Megatrends Inc, so i downloaded the motherboard finder software from their site and this is what comes up
| Quote: | AMIBIOS Motherboard Manufacturer Identification
Version 1.4 (01/12/2004) Copyright 2003 American Megatrends, Inc.
This file has recorded information useful in identifying the manufacturer
of this motherboard. The information is listed below:
ALERT: This BIOS has been identified as NEC BIOS!
Please contact NEC for motherboard support ... https://www.nec.com
NO STANDARD AMIBIOS IDENTIFICATION STRING DETECTED. PLEASE DO NOT CONTACT AMI TECH SUPPORT CONCERNING THIS PRODUCT.
For more information on upgrading your BIOS go to https://www.ami.com/support/bios.cfm?refer=mbid
SMBIOS info:
Manufacturer :
Product Name : P4S61
Version : 1.0
Serial Number: 00000000
but when i go to NEC site i can find anything with regards to updating the bios!? |
| swaffs |
 swaffs World Chat Champion
 Posted: 15:44 - 27 Sep 2007 Post subject: |
If this is XP:
Does your system know what monitor is connected?
In the display settings does it say
Display
(Default monitor)
xxx resolution
Try downloading the INF file for that monitor. (from the manufacturers site)
If it's still not allowing it, turn off the “Hide modes that this monitor cannot display” checkbox (under the adapter/advanced tab).
You will then be able to select any display mode , even if windows thinks it is incorrect for that monitor. Be carefull of selecting rediculous settings though, and if the screen goes weird, just wait for it to come back again (about 20 seconds) (or press ESC)
Be very carefull with that, and if you select a mode that screws everything up, you may need to reboot and push F8 to go into VGA mode.
Don't forget to run some colour profiling as well so your colours are true. at least load the colour profile that comes with the monitor.
Swaffs ____________________ Swaffs Photography |
BCF vinyl stickers
"Look not back in anger, nor forward in fear, but around you in awareness." |
| JGY6000 |
| willi |
 willi Spanner Monkey
 Posted: 23:10 - 27 Sep 2007 Post subject: |
i find that 1024 x 768 pixels is better on my 19"
1440x900 just makes everything to small.
also check out microsoft update there will probably be an update for your screen there aswell under custom. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/
wat goes around comes around. |
| DEN MONKEY |
 DEN MONKEY World Chat Champion
 Posted: 07:58 - 28 Sep 2007 Post subject: |
The story goes that lcd monitors give a crisper picture at their native resolution though.
So its best to try and have it matched to the res setting on your graphics card.
I just put a new system together for my father and when I tested a relatively cheap graphics card I got for him on an old crt monitor it did not offer resolution upto the required level.
Upon connecting it to the lcd monitor with the dvi connection I was then offered the increased res.
So make sure you're not using the old analogue vga connection instead ( blue one ) this may be your issue.
A quick google also suggests ensuring your video card drivers are up to date and using the control panel from the card software instead of the usual interface offered by windows.
google 1440 x 900 lcd resolution and you will be face with a bit of reading.
Good luck  ____________________ meh |
| Glen |
 Glen Spanner Monkey
| leeves |
 leeves Two Stroke Sniffer
| JGY6000 |
The last post was made 18 years, 133 days ago. Instead of replying here, would creating a new thread be more useful? |
