| stuextreme |
 stuextreme L Plate Warrior
| moonym20 |
 moonym20 Could Be A Chat Bot
 Posted: 20:58 - 01 Oct 2007 Post subject: |
have you tried looking on [url]https://www.r6messagenet.com [/url] ?
Those guys should be able to get you sorted, i do know that Yamaha can be bastards for moving pins and connectors around on the Loom, when i installed my Digi-Gear the pins were not any near the order they should have been in according to the tech manual for my bike...
if your oil and everything is at the right level it does sound like a connection is wrong somewhere.
out of interest how was the 'arse end' conversion with you?? you mentioned that you switched the looms around??
anyways, good luck getting it sorted  ____________________ A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot  |
| stuextreme |
 Posted: 21:11 - 01 Oct 2007 Post subject: |
thanks for the reply i have just join that r6 forum so will wait for answers soon.
as for arse end had a few little teethin problems in settin it up like the gap between the rear seat ! but all i had to do was drill the plastic hole so i could move it around and got it lined up perfect
as you know didn't fancy cuttin the tray and so changed the loom also the left side grip controls as plugs where different and had couple of extra wires on there also had to cut and bullet connect the one earth and one other wire which was on the block and the rest just plugs straight in.
i've just been told it could be the clocks as they slightly differ between 99 and 02
can anyone vow for this
thanks stu |
| moonym20 |
 Posted: 21:16 - 01 Oct 2007 Post subject: |
thats a shit load of loom work, it is most likely that there is a crossed connection there somwhere,
Most people i have heard of just added the 2002 rear, chopped the undertail to keep the battery box and just spliced the new lights into the loom.. personally i hate doing sparky work
If it was me i would be tempted to let an auto spark cast an eye over it all simply because if there is a short somewhere there are a lot of things to fry and bugger up
there will be someone on R6msgnet who will get you sorted... im very sure they also have the arse end conversion guide on there was well...  ____________________ A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot  |
| stuextreme |
 Posted: 21:47 - 01 Oct 2007 Post subject: |
cheers mate will keep you posted on the job just tryin to sorce out some 01-02 clocks to try as you can't tell what model they are off on ebay as they all look the same
stu |
The last post was made 19 years, 25 days ago. Instead of replying here, would creating a new thread be more useful? |
