Is the throttle part of the MOT?
DaveH
PostPosted: 15:00 - 02 Oct 2007    Post subject: Is the throttle part of the MOT? Reply with quote
Hi,
Bike has failed its MOT, on 4 things, but one of them is that the throttle does not return...now have never noticed this myself and went to check on a couple of MOT site, what the check was, but can't find the test method or fail criteria.
Can anyone tell me what the details are?
Thanks
Dave
https://www.timhastingsracing.co.uk/
ZX7R & ER6F
Whosthedaddy
PostPosted: 15:19 - 02 Oct 2007    Post subject: Reply with quote
If the throttle sticks or doesn't return to a neutral position then yes its a fail, not quite sure how to resolve it to be honest apart from some lube on the cables and check for binding, I'm kinda stumped?
veeeffarr
PostPosted: 15:37 - 02 Oct 2007    Post subject: Reply with quote
Aftermarket grips?
PostPosted: 17:28 - 02 Oct 2007    Post subject: Reply with quote
Causes of this can be:
Not enough free-play
Crud under the throttle tube causing it to stick to the bar
Cable gummed-up with road film
Bad cable routing causing tight bends
Aftermarket grips rubbing on bar ends/switchgear
Damaged outer-cable (from getting caught in the lock-stops)
Frayed inner-cable
Check all of the above it's likely to be one of them or a combination of some.
The last post was made 19 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.40 Sec - Server Load: 1.01 - MySQL Queries: 15 - Page Size: 40.44 Kb
