can I bodge it?
Timmeh
PostPosted: 16:40 - 03 Oct 2007    Post subject: can I bodge it? Reply with quote
'lo.
Muppet-boy here has managed to over-tighten his sump bolt on his CBR and stripped the threads. It screws up, but won't tighten. It doesn't seem to leak with the bike standing, although vibration from riding it will prolly make it fall out.
Can I be lazy and use some threadlock to keep it in its place or have I got to take the sump off and use a helicoil?
Cheers. Thumbs Up
PostPosted: 16:41 - 03 Oct 2007    Post subject: Reply with quote
I would say do it properly.
Thread lock is not likely to be that good on an oily thread.....
Timmeh
PostPosted: 16:45 - 03 Oct 2007    Post subject: Reply with quote
hmmmmmm.
I fear you'd say that.
Oh well.
steveh
PostPosted: 17:59 - 03 Oct 2007    Post subject: Reply with quote
Find a big tap and re tap it to a bigger size, if you can get hold of a bigger bolt, use a grub screw.
Lock tight it, and you could even put some wire on it so you dont loose it if it falls out.
or if you want to bodge...
liquid metal (prolly wont work)
Take the sump off, put a nut and bolt thru it with some downty washers (washers with rubber seals) or even copper washers.
Weld the hole up, make a new one at a later date.
Areldite, or liquid metal the bolt in place, note: youd have to take sump off, as it wont take if theres oil on there.
Or...
Buy a new sump
Steve Thumbs Up
TUG
PostPosted: 20:36 - 03 Oct 2007    Post subject: Reply with quote
you stripped the thread off the sump plug or the sump? my mate over tightedned mine and i had to replace the sump, few months later he cross threaded his rear caliper bolt after attempting to change his rear pads...
anyway back to this subject, if its the plug thats damaged then take it to a local mech to repair the thread if its the sump itself then a big tap might do? am not sure though its a bit tricky.
hope you sort it mate, be less heavy handed Thumbs Up
Haz ER-5, innit!
Ichy
PostPosted: 22:08 - 03 Oct 2007    Post subject: Reply with quote
What do you mean by sump bolt?
I found a place that was selling Helicoil kits for less than £20, including spark plug and sump plug inserts. I shall have to search for it again.
Timmeh
PostPosted: 10:32 - 04 Oct 2007    Post subject: Reply with quote
That sounds like what I'll do.
I don't really want to have to take the bike to pieces to fix it, especially outside my house.
I don't think plod/neighbours would take to that too kindly.
Now I need to find someone who sells helicoils..... hmm.
sickpup
Old Timer
PostPosted: 10:55 - 04 Oct 2007    Post subject: Reply with quote
Check the sump bolt size. Some Honda's come with a 12mm bolt so the hole can be taken out to 14mm.
Timmeh
PostPosted: 16:50 - 04 Oct 2007    Post subject: Reply with quote
Indeed it is, it's an M12x20.
Just trekked all over west london trying to find someone who sells helicoil kits.
No joy.
Crying or Very sad
steveh
PostPosted: 19:02 - 04 Oct 2007    Post subject: Reply with quote
taking the sump off isnt a big job, its only fairings really.
Plod cant say anything to you for fixing your bike.
PostPosted: 19:18 - 04 Oct 2007    Post subject: Reply with quote
Try this guy:-
M12 x 1.25mm
M12 x 1mm
Hopefully he can get one to you quickly.
bish777
JB Weld will fit the bolt in and make it oil tight, until you can get it repaired properly.
GSXR1100J
Timmeh
PostPosted: 22:27 - 04 Oct 2007    Post subject: Reply with quote
fairings and exhaust; plus I'd have to buy a new sump gasket and new bolts. There's little chance Honda will have them in time for the weekend.
Plus they can have a go at you for spilling oil everywhere, as one of my friends recently found out.
Keith and bish; cheers for the help.
TUG
PostPosted: 23:25 - 04 Oct 2007    Post subject: Reply with quote
instant gasket works a treat, used it on my starter cover, sump and clutch cover not one has leaked. Thumbs Up
Haz ER-5, innit!
The last post was made 18 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 87.01 Kb
