Overheating smell....???
david240968
PostPosted: 23:19 - 03 Oct 2007    Post subject: Overheating smell....??? Reply with quote
i have a 2000 r6 and have noticed recently when idling at lights etc. that i can smell what i can only describe as an overheating smell. everything is running fine, just not sure if i should worry about the smell or what may be causing it. it runs consistantly at 82 degrees when idling and a bit less running around if that is of any help to diagnose it.
druidsam
PostPosted: 23:31 - 03 Oct 2007    Post subject: Reply with quote
do you know at what temperature the radiator fan cuts in at?..i would only worry if it went above that temperature and the fan didnt run,it could just be that its a normal smell and can only be noticed when the bike comes to a stop,or have you put some sort of polish on the exhaust pipe or engine casings?
...........................Sam
trust me! I'm a druid
https://www.bikerforum.co.uk/
sagalout
PostPosted: 11:26 - 04 Oct 2007    Post subject: Reply with quote
You'll also get a 'burning' sort of smell when its been raining. Water on the road collects bits of rubber etc, splashes onto downpipes/engine and then burns off.
As long as your temps look ok I wouldnt worry
bish777
PostPosted: 12:24 - 04 Oct 2007    Post subject: Reply with quote
You may have a little oil coming out of abreather of a very small leak somewhere, which gives a cooking aroma. Thats where alot of old bikes get their smell. Your R6 is probably just developing a small leak somewheres.
GSXR1100J
The last post was made 18 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 39.5 Kb
