dt125 cutting out at top end revs...
rik220
PostPosted: 18:19 - 04 Oct 2007    Post subject: dt125 cutting out at top end revs... Reply with quote
Basically im interested in buying a dt125 (1999) for cheap, to use when im 17 in march. The one im interested in runs but as i said it cuts out at top end revs. Would it be powervalves causing the bother? Or carb needing set up? What do you think?
Cheers
Rik
Honda x8r. Aprilia Rs50
Honda CR85
Renault Clio 1.2
darkangel
PostPosted: 23:50 - 04 Oct 2007    Post subject: Reply with quote
cut out as in the engine simply dies, or that it doesn't let you reach those revs?
If the powervalve was setup incorrectly what would happen is it would most likely rev freely in neutral but when moving at speeds the bike would refuse to rev upto 10k, the engine would not cut out though.
Ohh and by the way your better off buying a more expensive better condition bike then a pile of ****, you will save yourself time and money in the long-run.
The last post was made 18 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 31.19 Kb
