My speedo died :(
alt
PostPosted: 18:56 - 24 Nov 2003    Post subject: My speedo died :( Reply with quote
When driving along today, I noticed my speedo died on me Sad
When I went to inspect the cable, I noticed that the rubber had torn in a place, but the cable itself is still in-tact.
Could this me by problem? Just thought id ask before I go removing the wheel to look at the sensor.
Shaun
Likes 'em bent
PostPosted: 18:58 - 24 Nov 2003    Post subject: Reply with quote
I had this problem several times in 2 months on my RS, take the cable off and see if its broken. I do suspect that the tear will be the problem though, if not kick and scream at your bike and stamp on the speedo drive then go to buy a new one!
Also worth taking the speedo drive off before you begin to stamp on it!
alt
PostPosted: 19:00 - 24 Nov 2003    Post subject: Reply with quote
Do I have to remove the front wheel to remove the cable? Confused
PostPosted: 19:01 - 24 Nov 2003    Post subject: Reply with quote
No, but you do have to remove it to take out the speedo drive.
The speedo drive on the RS125 can be very short lived for some reason.
alt
PostPosted: 19:04 - 24 Nov 2003    Post subject: Reply with quote
Cheers for the info.. Sorry to seem to stupid, but is the speedo cable a solid cable? (Never played with one before).
Shaun
Likes 'em bent
PostPosted: 19:05 - 24 Nov 2003    Post subject: Reply with quote
Yes it is, it'll be the connected underneath your speedo and straight down to the front wheel, should just unscrew!
alt
PostPosted: 19:10 - 24 Nov 2003    Post subject: Reply with quote
Cheers, will play about with it when I get home.
Should I unscrew from the wheel or speedo? (Speedo end looks very aqward to get at!)
Shaun
Likes 'em bent
PostPosted: 19:12 - 24 Nov 2003    Post subject: Reply with quote
Both to get a better look at it, speedo end is very awkward to get at but once undone will just come right off hopefully with the cable in one piece!
alt
PostPosted: 19:14 - 24 Nov 2003    Post subject: Reply with quote
Thanks, will update when I find the problem... Hopefully its just the cable Rolling Eyes
The last post was made 22 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.02 - MySQL Queries: 13 - Page Size: 59.42 Kb
