NC30 R3 which model is this ?
blownygti
PostPosted: 12:15 - 18 Oct 2007    Post subject: NC30 R3 which model is this ? Reply with quote
I am going to view one on sat is this the later model NC30 ? its on an M reg registed here in 1999 if so what are the differences between this an earlier models ?
johnsilva
PostPosted: 12:22 - 18 Oct 2007    Post subject: Reply with quote
wow
Current Bikes: ZX7R P5; KR1S C2; GPX250R F3
Previously: CBR400RR-R; YQ50 Aerox
aaron0288
PostPosted: 12:28 - 18 Oct 2007    Post subject: Reply with quote
think M reg was the vey last of the nc30s. think the only difference is the front forks.
Past bikes - 1991 NC30 - 1991 Bandit 400 - 1989 CBR400 NC23 - 1993 NC30 - 1991 ZXR400 L1 - 1993 NC30 - 2003 CBR600RR3 - 2003 Ducati 900SS - 2000 SP1 - 2013 899 Panigale
Current bikes - 2013 Street Triple R + 2006 R6 + 2003 SV1000S
craigs23
Mr Muscle
PostPosted: 12:41 - 18 Oct 2007    Post subject: Reply with quote
Can't see a pic - most likely down to Safari at work....
Not too many changes from later NC30s - upgraded forks with rebound/preload adjustment (similar internals to RVFs), changes to jets (run a bit richer), rear shock has a remote reservoir, to name but a few.
Registered date is usually different from manufactured date when it comes to import bikes...
MementoMori
PostPosted: 12:43 - 18 Oct 2007    Post subject: Reply with quote
I believe the NC30 was once officially referred to as a VFR400-R3, so it's not a particular model of NC30. More another name for the NC30 model.
Honda didn't bring out any variants of the '30. They tweaked it here and there. For example earlier bikes have same-size carb jets and crap front forks and later bikes came with a rear shock remote reservoir and carb jets differed between front and rear.
EDIT: Ballsacks. If you snooze, you lose, what what.
The tiger who came for a pint
blownygti
PostPosted: 12:46 - 18 Oct 2007    Post subject: Reply with quote
Honda didn't bring out any variants of the '30. They tweaked it here and there. For example earlier bikes have same-size carb jets and crap front forks and later bikes came with a remote reservoir and carb jets differed between front and rear.
thannks mate this one is an M reg so must be one f the last ones Smile whats betetr about the remote reservior forks and crb setup as I am not to well up on the NC30
craigs23
Mr Muscle
PostPosted: 12:52 - 18 Oct 2007    Post subject: Reply with quote
Partial Credit.
The model codes for NC30s range from VFR400RK - VFR400RN: mostly down to colour variations. R3 could be a paint variation of an OE scheme, or the 3rd installment of the model, just named incorrectly.
MementoMori
PostPosted: 13:01 - 18 Oct 2007    Post subject: Reply with quote
The forks on the newer models are cartridge forks, which are pretty much standard these days, especially with Honda. This means you can adjust preload and rebound whereas with the older damping rod forks, you could only adjust the preload. The earlier NC30s are pretty notorious for having poor, soft suspension.
The early carb jets were all small and were all the same size. With the newer bikes, they opened them up to something like 115 at the front and erm... 117/118 at the back, sorry I can't remember specifically. So, as Craig said, they run richer.
Oh yeah, and with the older forks, well because of their old-ness, they will be harder to play with in the future, should you want to.
Hope that helps, can't claim to know everything about these bikes but hopefully gives you a rough idea.
aaron0288
PostPosted: 13:02 - 18 Oct 2007    Post subject: Reply with quote
Isn't the R3 the red, white + blue model???
MementoMori
PostPosted: 13:03 - 18 Oct 2007    Post subject: Reply with quote
Partial Credit.
Ah I see, that makes much more sense.
Thanks. Thumbs Up
The last post was made 19 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.28 - MySQL Queries: 15 - Page Size: 65.89 Kb
