| TUG |
 TUG World Chat Champion
| Paddy Blake |
| TUG |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 01:18 - 19 Oct 2007 Post subject: |
you'd be better off reboreing it than turbo or supercharging it,
you'd have to throw a fortune at it and lots of time to get a turbo or super charger running smoothly,
even reboring it would cost more than buying a 600cc engine and making that fit, you could sell the 400cc engine and recover some of the money buying the 600cc engine.
or if you were feeling really keen, the 1000cc engines seem to go for cheaper than the 600's muhuhahah
it would probably be a mission squeezing it inthere and probly would require strengthening of the 400 frame and possibly new brakes,
but anything is possible if you're keen enough ____________________ the humans are dead
I kick arse for the lord
| TUG |
 Posted: 01:24 - 19 Oct 2007 Post subject: |
maybe buying a 600 and .......
turbo that?
to be honest with you i'd just like to give my fzr that stupidly insane boost of a blower. i know its more logical to buy a bigger bike/engine, but to be honest am keeping this bike so anything bigger i do get wont last as long as my fzr, and my soon to be CG.
i'm more keen to do it after i read the vfr800 thread, i saw a turbo on a 400 with 600 engine etc that he did and it looked great but like i said after reading the vfr800 one its made me want to do it more.
i just want the 400 engine to produce a better bhp with the turbo.
something to do lol. ____________________ Haz ER-5, innit! |
| bladerunner |
| TUG |
| Big Pete |
 Big Pete Spanner Monkey
 Posted: 09:19 - 19 Oct 2007 Post subject: |
technically possible, practically difficult. To get any sort of decent performance you are going to need a a tiny turbo unit, something like the IHI RHB5 unit that was on CX500 turbos. Then you need a custom inlet manifold, exhaust manifold, possibly new carbs, ideally an intercooler (depending on boost level), ignition remapping is prolly a good idea, and you may need an aftermarket ignition unit depending on the spark voltage the current setup produces.
If you did all that and pushed it hard, you might get as much as 100% more power, which is going to put you into modern 600 territory. That prolly means a new heavy duty clutch set, maybe reworked gearbox internals, bigger rad, bigger oil cooler, maybe bigger oil pump, sump spacer, maybe clutch cover spacer, low compression pistons/head work, maybe cams.
If it was mine, I'd stick a 600 lump in, its simpler, its going to be more reliable and spares are easier to get hold of. ____________________ Trust me, I`m an engineer
GarageOfPower.co.uk |
| NSR Mick |
 NSR Mick World Chat Champion
 Posted: 11:10 - 19 Oct 2007 Post subject: |
The FZR400 engine is not known for being strong, let alone when tuned. Nor is the FZR600 engine (which had a regular habit on throwing rods out of the cases when they raced them). Bolting a turbo on would make them about as reliable as a cardboard submarine.
If you did turbo it then it would be a massive amount of work. A turbo would be required, all the exhaust manifolds, inlet manifolds, probably an intercooler (not sure where you would fit that), sealed carbs (with the float bowl vents going into the manifolds so the float bowls were pressurised by the same amount as the intake air), reduced compression (either bodged with a spacer plate or with some custom low compression pistons), programmable ignition timing, higher pressure fuel pump, almost certainly stronger rods to take the extra load, heavy duty clutch, etc.
Realistically you would land up with something that cost far more than a pretty new R6 yet was slower and heavier, with a dubious power delivery.
| hmmmnz |
| TUG |
 Posted: 12:22 - 19 Oct 2007 Post subject: |
if i did that then its beating the whole 400 cc thing, on the other hand, if i didnt fit a turbo what other performance mods could i do that wont throw my rods through the side? some one mentioned nos before, what work would i need for that?
keep the suggestions coming and thanks everyone.  ____________________ Haz ER-5, innit! |
 Posted: 12:36 - 19 Oct 2007 Post subject: |
Any serious tuning is likely to throw the rods through the side (a decent blueprinting job would probably gain power and reliability though). Although NOS is a hell of a lot cheaper and possibly easier to set up from scratch than a turbo (although you will really struggle to find an insurance company to touch you with it).
For very rough idea of costs, a turbo kit from Big CC Racing would start at about £4500. OK, you can save a bit of money sourcing 2nd hand bits, but you can also add a load to the cost by having to get one off manifolds designed and made. Spending at least 5 times the value of the bike is not really a good idea.
| hmmmnz |
 Posted: 12:39 - 19 Oct 2007 Post subject: |
nos is notoriously bad for engines as it causes the bike to run lean unless you can up the fuel while the n20 is being injected.
then you have the problem that its really stressing the engine,
you could lighten all the connecting rods buy stronger lighter valves. ect ect, there is plenty you could do, but really the increse in proformance will be minimal.
c'mon, throw a couple of hundred at it and put the 1000 in it  ____________________ the humans are dead
| TUG |
| TUG |
 Posted: 12:42 - 19 Oct 2007 Post subject: |
keep throwin in the suggestions though, its a good read this.  ____________________ Haz ER-5, innit! |
| TUG |
| NSR Mick |
 Posted: 12:57 - 19 Oct 2007 Post subject: |
It cost me less than £300 to get the 1000 into the 4.
I did have a slight advantage though. I had both bikes complete so had all the loom, cdi and carbs etc allready.
Most of the cost was getting a good welder to lop off some of the engine mounts and re-weld them so they would line up with the 1000's mount points.
One of the rear mounts was a perfect match for the 1000 so I didnt even need to touch that which helped a lot.
I'v even found a pic of it. Forgive it looking tatty as hell, that was taken in it's very early stages. I did end up fightering it.
https://i8.photobucket.com/albums/a50/micklivesey/old%20bikes/LookingTattybutallThere.jpg ____________________ If you dont like the way that I ride.......Stop trying to keep up!!! |
| TUG |
| NSR Mick |
 Posted: 13:02 - 19 Oct 2007 Post subject: |
I think the 400 is ok with a 6 in it.
Mine went pearshaped because one of the engine mounts came loose and it twisted it.  ____________________ If you dont like the way that I ride.......Stop trying to keep up!!! |
| JaysonM |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 JaysonM L Plate Warrior
 Posted: 13:03 - 19 Oct 2007 Post subject: |
I'd like to advise you 1000 cm3 volume! [email protected] |
| TUG |
The last post was made 18 years, 314 days ago. Instead of replying here, would creating a new thread be more useful? |
