Old Hard Drive....
RealNinja
PostPosted: 11:22 - 27 Oct 2007    Post subject: Old Hard Drive.... Reply with quote
I have just upgraded my whole system, including hard drive, after killing my last P.C Embarassed
Unfortunatly I did not get the opportunity to save all my music and photos to CD's and DVD's before the P.C went bye-bye, so now I have all the stufff on the old HD.
Now, I can access the HD cos I have an extenal case that will accept it, and the new PC can see into it, but it won't (can't) access the 'user' folder, which is where all my photos etc etc are.....!
Being a techno-numpty I don't know how to sort this Sad
Can anyone help?
You will become my force of retribution. Where you tread, doom will follow. Go now and claim your destiny
Hetzer
PostPosted: 11:28 - 27 Oct 2007    Post subject: Reply with quote
Try re-naming the folder.
Try dragging the folder to your new HD.
Jamie.
PostPosted: 12:53 - 27 Oct 2007    Post subject: Reply with quote
Did you have a password on your account on the old comp? This is most likely why you can't access the files.
2 ways to do this, If you can boot your old hdd up, Just remove any passwords from the user accounts and that should sort it, But since you upgraded i'm guessing the hdd won't boot with the new hardware. (Try booting it in safe mode to remove the password)
OR
I'm not on a windows machine and i'm doing this from memory so you might need to read between the lines if I miss a bit. I've googled the pics so yours might look slightly different
Boot into safe mode (Press F8 a few times before the windows loading screen comes up)
Find the folder you can't access, Right click it and click Sharing and Security.
You should have this:
https://img297.imageshack.us/img297/9813/restoresecuritytabwindowx9.jpg
Click Security then Advanced at the bottom.
You should now have this:
https://web.mit.edu/ist/products/winxp/advanced/backup02_permissions.gif
Select the 'Administrator' account.
Check the 'Replace Permission entries on all.............'
Hit Apply.
I haven't done this in a while so hopefully this helps
RealNinja
PostPosted: 17:54 - 31 Oct 2007    Post subject: Reply with quote
I've still not been able to access the user folder on the old drive, but I have a question.....
If I was to disconnect the hadr drive on another computer and connect my old hard drive (which contains windows etc etc) and boot the other computer up, would that work?
In that position I could just burn all the stuff I want onto a DVD(s) and then transfer it to my new one.
Is that an option or not?
Jamie.
PostPosted: 12:20 - 01 Nov 2007    Post subject: Reply with quote
It will work if the motherboard has the same chipset, Which it probably won't.
RealNinja
PostPosted: 14:48 - 03 Nov 2007    Post subject: Reply with quote
Cheers dude, the old safe mode thing worked after I had spent a little bit of patience with it Embarassed
Karma dispatched Thumbs Up
The last post was made 19 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 48.9 Kb
