Gators
gene_cann
PostPosted: 00:12 - 31 Oct 2007    Post subject: Gators Reply with quote
Good Evening,
After failing in my mission to find Fork Gators for my Cougar (I need them to get through the MOT pitting on fork within normal movement range!) I had ago at making a sleve from an old inner-tube but there was to much resistance (the fork would not return to neutral position naturally) So does anyone have any idea for some home made gators or where I get some from before monday! I am in Portsmouth
Cheer's
Gene
"If your not part of the solution then your part of the problem"
T1z3R
PostPosted: 00:55 - 31 Oct 2007    Post subject: Reply with quote
bin bags.
duck my sick!
gene_cann
PostPosted: 07:28 - 31 Oct 2007    Post subject: Reply with quote
Great Idea, I will try that out. Thanks
sickpup
Old Timer
PostPosted: 13:07 - 31 Oct 2007    Post subject: Reply with quote
Or you can ask me as I have them in stock.
gene_cann
PostPosted: 01:52 - 01 Nov 2007    Post subject: My New Gaiters Reply with quote
HI
Thanks for the Bin Bag idea it works a treat see pic!
Sickpup - Thankyou for your input but this is only a temporary measure (MOT monday!) still please send me a link to the Gaiters I searched your shop but no luck!
T1z3R
PostPosted: 02:03 - 01 Nov 2007    Post subject: Reply with quote
should serve you well for an MOT mate Thumbs Up
duck my sick!
sickpup
Old Timer
PostPosted: 13:52 - 01 Nov 2007    Post subject: Reply with quote
They're not in the shop, very little is.
Why only a temporary measure. surely you would be better off fitting them when you get new fork legs so this doesn't happen again?
fenton
PostPosted: 02:31 - 02 Nov 2007    Post subject: Reply with quote
Id be wary of putting anything on my forks. I know someone who did a similar thing, i cant remember exactly what he used but it went into the actual fork and fucked one of the seals up causing it to leak everywhere. Best of doing as pup said and getting proper gaitors to prevent it from happening in the first place.
PEANUT BUTTER JELLY TIME!!!!! I cannot be held liable for anything that i post.
CBR400RR NC29 ( '06 - '09 )... TL1000 RK1 ( '10 - present )
b-f-c
PostPosted: 10:29 - 02 Nov 2007    Post subject: Reply with quote
How much for a pair to fit FJ11 forks - 41mm diameter, about 200mm long when suspension static?
And don't rot out in 8 months
PostPosted: 14:50 - 02 Nov 2007    Post subject: Reply with quote
it might also help if you didn't search for an abbreviation of alligator.
They are, in fact, called fork gaiters.
https://www.google.co.uk/search?sourceid=navclient&ie=UTF-8&rlz=1T4GGLJ_enGB215GB215&q=fork+gaiters
Although the M and P website appears to spell it both Gaiter and Gaitor... perhaps Gaitor is an americanism.
I always assumed they were the same as the things you wear on your legs... Smile
The last post was made 18 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 63.89 Kb
