cg bigger battery
virus
PostPosted: 12:10 - 31 Oct 2007    Post subject: cg bigger battery Reply with quote
is there anyway i can boost my CGs battery, i have a 12v 10a battery going spare and place to put it but how would i wire it in without melting the standard wiring?
or would it be possible to get led indi bulbs that fit in the standard holder?
im getting pissed off with my indis fading when i roll off the throttle even though my battery is fully charged
Cheers
John
own: 81 xs1100g...
c_dug
PostPosted: 12:33 - 31 Oct 2007    Post subject: Reply with quote
have you tried a new standard battery?
virus
PostPosted: 15:41 - 31 Oct 2007    Post subject: Reply with quote
yeah, i think there just pathetically shite as standard, something like 5 amps?
Cheers
John
own: 81 xs1100g...
Finglonga
PostPosted: 17:11 - 31 Oct 2007    Post subject: Reply with quote
The bike will only draw what it needs so size of battery won't matter. Even if you get a short with the standard battery you will get fire and smoke.
Physical size is your limiting factor as to if it fits. Wink
Andy Sez....
F.Y.Y.F.F.
bugsy46
Village Idiot
PostPosted: 19:12 - 31 Oct 2007    Post subject: Reply with quote
thats because its all the bike needs!? how is a higher amperage battery going to solve it?
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
virus
PostPosted: 21:39 - 31 Oct 2007    Post subject: Reply with quote
just though it mention physical size before somone said anything bigger wont fit in the battery box.
My battery is fully charged yet the indicators slow down and flash really weak unless im at pretty high revs.
Would LEDs work?
Cheers
John
own: 81 xs1100g...
bugsy46
Village Idiot
PostPosted: 22:15 - 31 Oct 2007    Post subject: Reply with quote
Maybe your charging system isnt putting out enough voltage at low end revs? Do you have the right winker bulbs in?
finpos
PostPosted: 22:23 - 31 Oct 2007    Post subject: Reply with quote
My suggestion would be to go for a new, standard battery first. Even if yours is fully charged, it may be old and busted and fully charged. The piddly little batteries on kick-start bikes can really go off in terms of performance but you do not realise because they never have any real big load on them (headlight, electric starter etc.)
f.
virus
PostPosted: 10:33 - 01 Nov 2007    Post subject: Reply with quote
new battery in there running 12.4v across and 14v when running at higher revs
Cheers
John
own: 81 xs1100g...
virus
PostPosted: 23:23 - 01 Nov 2007    Post subject: Reply with quote
i can fit my 12 12 in the flash bang crate on the back with a good mount so would it be advisable to run it as a parallel battery with a fuse in line?
Cheers
John
own: 81 xs1100g...
finpos
PostPosted: 23:27 - 01 Nov 2007    Post subject: Reply with quote
It's worth a shot - my concern would be that if the charging system lacks the beans to keep the standard battery charged, it'll struggle with a higher rated one or even more so with two.
f.
virus
PostPosted: 23:42 - 01 Nov 2007    Post subject: Reply with quote
hmmm, i see what you mean, perhaps regular charging of the second battery?
Cheers
John
own: 81 xs1100g...
finpos
PostPosted: 00:42 - 02 Nov 2007    Post subject: Reply with quote
What I'd do is charge up your "better" battery, mount it up temporarily, disconnect the old one and run a wire up to the new one. See how it gets on. Easy to swap back if it doesn't work.
Stick a fuse the same rating as the existing one near the battery if you are worried about small electrical fires Smile.
f.
The last post was made 19 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 76.46 Kb
