Starting problems
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2
The BeefMeister
PostPosted: 20:48 - 02 Dec 2003    Post subject: Reply with quote
Dont know if this is related in anyway, but my AR50 had something wrong with the throttle. When you pull away you werent able to pull it right back, this would cause it to start die but once it got above a certain amount of revs I could pull it right back. Shocked A bit strange if you ask me?!
Another thing was it usually never started, was always kept in a garage with petrol tap turned off etc. That bike was nothing but trouble for me.
The clutch cable snapped so I went to get it fixed and that same day I wrote the bike off Laughing Oh well.
Anyway, good luck with your bike.
"Put your hands up motherstickers, this is a f*ck up!"
John
PostPosted: 21:11 - 02 Dec 2003    Post subject: Reply with quote
Very Happy
Nearly used the entire can, and it took around 400 kicks, but it's back working!
YAY!!!!!!!!! Smile Smile Smile Smile
TT600 neeeeeeeeeeeeeeeeeeowwww!
Danny
Ask Me About Stoppie School
PostPosted: 21:26 - 02 Dec 2003    Post subject: Reply with quote
Very Happy Good to hear it mate. Very Happy
The BeefMeister
PostPosted: 21:29 - 02 Dec 2003    Post subject: Reply with quote
Nice one.
The AR's I believe had quite a strong engine, not particularly quick but well built, I had very few problems with mine, the ones I did have were minor.
Anyways, well done getting your bike running again.
John
PostPosted: 22:22 - 02 Dec 2003    Post subject: Reply with quote
Thank you!
(esp Keith Mr. Green )
I hadn't been on it for about a month, and it's such an amazing feeling to ride it again. Smile
I also got cut up twice, and overtaken annoyingly once. Just need to put everything back propperly now. Can't wait for tommorrow! Smile
John
PostPosted: 13:29 - 03 Dec 2003    Post subject: Reply with quote
ARGH!
Bike started after around 10 kicks, then I went and got my tax, booted the MOT for tommorrow and trundled off for a little ride.
Bike lost power, changed down and it started going again, then lost power once more. Did that from 4th to 1st gear. Now it's dead again.
Does someone hate me or something? Mad
McJamweasel
BCF Junkie
PostPosted: 13:32 - 03 Dec 2003    Post subject: Reply with quote
Have you checked the fuel line? It may just be kinked or blocked. Try cleaning the carb as well.
PostPosted: 13:33 - 03 Dec 2003    Post subject: Reply with quote
This may seem like a silly question, but you do have plenty of petrol in there? Just that if it had flooded from fuel dripping through, plus various attempts to start it and draining the carb it might well have used up quite a bit (my 1200 Bandit used something like 12 litres when parked up overnight when the carb floats stuck and I left it on prime by mistake).
John
Yeah it's full of fuel.
John
PostPosted: 13:42 - 03 Dec 2003    Post subject: Reply with quote
Fuel is coming through well also. Spark is pretty small though, wonder if that is the problem.
I've got a spare coil, not sure how but i can try and put that one in.
PostPosted: 13:47 - 03 Dec 2003    Post subject: Reply with quote
Change the spark plug first. However the coil is normally quite easy to change. Often just held in place with little more than a rubber band, and only a couple of wires going to it.
John
PostPosted: 14:13 - 03 Dec 2003    Post subject: Reply with quote
I give up.
Who wants the buy the thing? Neutral
John
PostPosted: 14:24 - 03 Dec 2003    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?p=161448#161448
Ha Ha Ha.
McJamweasel
BCF Junkie
PostPosted: 14:28 - 03 Dec 2003    Post subject: Reply with quote
I say again - don't sell it.
Have you tried a new spark plug? If you have and its not better try it with the other coil.
Again, have you cleaned the carb?
John
PostPosted: 14:58 - 03 Dec 2003    Post subject: Reply with quote
Thanks.
Carb is completely clean. Swopped it to the other coil and it didn't do anything at all. Put the original one back in, and it still didn't do anything. Swopped the plugs, still nothing.
Pull the rotting black crap off the wires (to the plug) and it started first kick. Now it's making a strange whistling noise, i'm really not going to go too close to that wire.
So it's working, again. Just hope it stays that way. MOT is back on again, for tommorrow morning. Moment of truth I guess... A pass would be real nice.
PostPosted: 15:04 - 03 Dec 2003    Post subject: Reply with quote
The cable from the coil to the plug can often be removed and replaced. Most bike shops should have a reel of that cable and it is not expensive. Normally it just screws onto the coil, and the plug cap just screw onto the other end.
Robby
Dirty Old Man
PostPosted: 01:03 - 04 Dec 2003    Post subject: Reply with quote
Check the condition of your battery too. I know its kickstart, but the battery may play a part in the igniton and a dead/dying one would suck a lot of power from your kicking it over.
John
PostPosted: 01:04 - 04 Dec 2003    Post subject: Reply with quote
It runs without the battery connected.
I'm 99% sure it's the wire. If it starts OK in the morning (with added glue and stuff) then i'll know it is! (It better do!)
Smile
The last post was made 22 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 100.47 Kb
