Chituma 125 de-restrict
bully
PostPosted: 17:58 - 03 Sep 2005    Post subject: Chituma 125 de-restrict Reply with quote
Hi, I have just purchased a chinese import it's a Chituma 125cc enduro. I have been told by many people it has the Honda cg 125 engine in it. The top end isn't up to much about 40- 45 mph. Ive been told there may be a restriction on the cdi unit. Does any body know how to de-restrict it? Thanks Martin
PostPosted: 18:21 - 03 Sep 2005    Post subject: Reply with quote
Doubt it would be restricted in that way. The CG engine is no ball of fire, and a sit up enduro style riding position will hit the performance a bit but I would still expect 55mph at the very least (assuming your speedo is averagly accurate).
How old is the bike? Has it been serviced? Check over the service items first (valve clearances, ignition timing if adjustable, points if fitted, air filter, etc) and see if you can find anything wrong.
nick.h
PostPosted: 18:22 - 03 Sep 2005    Post subject: Reply with quote
I assume that the bike is new.
If so have you ran it in?
Nick
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
bully
PostPosted: 23:23 - 03 Sep 2005    Post subject: Reply with quote
Nick
Yes it is new and is on the way to being run in. The guy I bought it off said that the engine would loosen up the more it was rode and it does seem that way. But he did say that all chinese bikes had got to have restriction on them and that he thought that it was in the cdi. As the revs seem to fall away at top end speed. Any ideas?
Martin
2Smoke
PostPosted: 20:08 - 04 Sep 2005    Post subject: Reply with quote
Nick
Martin
As a guess the 'restriction' will be the shite quality of build in the engine. Either that or there is a restrictor but its there because the manufacturers doubt its longetivity if its taken past 50mph Laughing
Sorry!
mchaggis
PostPosted: 20:12 - 04 Sep 2005    Post subject: Reply with quote
Sorry!
7000km on the clock so far, being ragged all the way! Razz
(Only one seizure, but that was my fault for being lazy in checking the oil. Whistle)
The 30+ year old design is probably what limits it, as well as a rather poor cloning of the CG engine. Reverse engineering is all very well and good, but it isn't the same as designing it in the first place.
I must not be a troll...
Mmmm, Guinness
There is a gap of 2 years, 62 days between these two posts...
speeddevil
PostPosted: 13:18 - 06 Nov 2007    Post subject: 50cc Reply with quote
hi my freind owns the 50cc version of this bike and it is restricted and does around 40 is there anyway he can get more speed from it thanx Smile
PostPosted: 13:26 - 06 Nov 2007    Post subject: Re: 50cc Reply with quote
Push it off a cliff
Rolling Eyes
Mudskipper
PostPosted: 13:35 - 06 Nov 2007    Post subject: Re: 50cc Reply with quote
https://www.clanbum.com/v6/e107_files/public/22_old_thread.jpg
Kal
PostPosted: 14:32 - 06 Nov 2007    Post subject: Re: Chituma 125 de-restrict Reply with quote
At best it will be a bad copy of one, the only Honda CG engines coming out of China are in CG125s badged as Hondas
A lot of these Chinese Bikes with CG engines don't even have copies of CG engines in them.
A Honda CG125 should be able to make 60-70mph depending on its state and weight/pyschosis of the rider.
Kal...
Scotch Bonnet
PostPosted: 16:05 - 06 Nov 2007    Post subject: Re: Chituma 125 de-restrict Reply with quote
Should be worried about my weight, or reassured about my mental health that i've still not quite managed to wring 70 out of mine in that case?
Hmmmm..... is it supposed to do that?
2001 CB500
The last post was made 18 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 72.77 Kb
