| Dischord |
 Dischord World Chat Champion
 Posted: 19:21 - 05 Nov 2007 Post subject: Modifying Yamahas powervalve system YPVS |
It's very difficult to tune the powervalve exactly how you want and I recall someone saying before they used to operate the powervalve via a bicycle gear changer mounted on the bars. I'm not sure if this is true to all YPVS systems but on the DT125 in stock form it doesn't open more than about 1/4 - 1/2 way when flat out.
Now this sounds like a really cool idea to me, keep the valve closed for town riding and then the second you hit the B roads / dual carriageway open the valve up for more top end grunt.
Has anyone tried anything like this before? would it even work or where they bullshitting? I think I could open the valve via a lever but having it return to the closed position is another thing entirely, would have to sort it out with a spring somehow.
Any ideas? would be interesting as you could switch from 15hp to 20+hp instantly! ____________________ 2012 KTM EXC 250
| G |
 G The Voice of Reason
| Dischord |
 Posted: 19:47 - 05 Nov 2007 Post subject: |
Interesting G, I didn't really consider using 2 levers - one for return! Thinking about it though that sounds like the simplest way of doing it.
My riding style varies quite a bit, I like to pull wheelies and go up the mountains so torque is pretty useful there but don't want to be left with 60MPH top-end DT125!
I reckon I could make a custom bracket and mount the 2 levers somewhere apart from the bars, so I could use the stock cables instead of extending them? ____________________ 2012 KTM EXC 250
Check out my vids - https://www.youtube.com/user/KTMSparky/videos |
| G |
 Posted: 21:02 - 05 Nov 2007 Post subject: |
I was thinking of a single one with a cable mounted the other way for the return, however you could use two too.
If you mounted them lower down you could use the original cables.
Oh and your title reads:
>>Yamahas YPVS powervalve system<<
which is
>>Yamahas Yamaha PowerValve System powervalve system<<  |
 Posted: 22:18 - 05 Nov 2007 Post subject: |
The lever on the bars for the power valve was a cheap bodge solution. Sold because it was far cheaper than the proper power valve kit from Yamaha.
Opening the valve further is not going to make the bike quicker. Effectively all it would do is start to close again. It is a half cylinder, and in the open position the engine side of the half cylinder will be flush with the top of the exhaust port. Open it further and the back end will just start to come down into the exhaust port.
Exactly the same as if you tried to open a throttle throttle butterfly beyond fully open.
| firefox |
 firefox World Chat Champion
| Dischord |
 Posted: 20:05 - 06 Nov 2007 Post subject: |
It already has an electric one, it's just a load of crap
@G - cheers for that, guess I better change it lol never knew what it stood for!
@Stinkwheel - I think people would probably mistake that for a bell
@Kickstart - I was under the impression it was a simply a valve that controls how big the exhaust port is? If I adjusted the 2 pulleys on the servo I saw massive gains in power and speed. Just thought a bike lever would be a quicker way of adjusting it instead of getting the spanners out every 5mins? ____________________ 2012 KTM EXC 250
| dougon2wheels |
 dougon2wheels Nitrous Nuisance
 Posted: 19:29 - 07 Nov 2007 Post subject: |
| Kickstart wrote: | | Dischord wrote: | @Kickstart - I was under the impression it was a simply a valve that controls how big the exhaust port is? If I adjusted the 2 pulleys on the servo I saw massive gains in power and speed. Just thought a bike lever would be a quicker way of adjusting it instead of getting the spanners out every 5mins? |
It is, and a servo motor is an even quicker way of adjusting it! Its main purpose it to effectively alter the exhaust port timing. You should not see any gains beyond it being set up correctly (although it is perfectly possible to have it only work on half the valve, it is split and just has a locating pin in the middle).
In its open position it should be producing best power. Adjusting the cable should give no more power at all.
Possible that a UK market restricted bike has a power valve control unit that does something silly at the revs go up.
Keith |
keith is correct,peak power(and peak port size)are when the valve is at the top of the travel,any futher and the port is closed down again,stick to using the servo and make sure that its set up correctly.........remove the exhaust,turn ignition on and feel up the port and make sure the powervalve feels flush with the port,if not adjust the cables and try again.
i run tuned engines on both my tdr250's and the mito 350,the tuning work includes porting the powervalve so the port is efectivly larger when the valve is open,it may be worth having a top endy tune put on the barrel if you want engine that goes like a switch.
but for me a peaky bike is no use on the road what so ever,try riding a standard stroker 250/350 with the powervalves wedged open,awful  |
| Dischord |
 Posted: 19:38 - 07 Nov 2007 Post subject: |
That's why I wanted a quick way to open and close the powervalve - with a lever for example
Like you say with the valve wide open the bike doesn't want to move unless it's over 8k or so and is almost fighting against you under that. Yet with it closed it has plenty of torque but basically no powerband at all.
Would be cool to pull off the mountain, flip a lever and have the bike ready to hit the roads without getting off and adjusting the cables! ____________________ 2012 KTM EXC 250
The last post was made 18 years, 340 days ago. Instead of replying here, would creating a new thread be more useful? |
