air horns
kwellsqpr1
PostPosted: 19:55 - 07 Nov 2007    Post subject: air horns Reply with quote
my mate has just wired up his airhorns without the rlay. would the compressor be noiser and slower if the battery is low.. or would it be because the relay hasnt been used?
keeping it rubber side down
Ichy
PostPosted: 21:21 - 07 Nov 2007    Post subject: Reply with quote
The relay has nothing to do with the noise or speed of the compressor, its just there to protect the wiring of the vehicle. The compressor should work fine if the bike is running.
Did you check the voltage of the compressor just incase?
Finglonga
PostPosted: 22:25 - 07 Nov 2007    Post subject: Reply with quote
Depends on if the wiring can carry the current to let the compressor spin up to its optimal speed. If not it wont be as loud and the wiring will overheat. Best run a relay on a fused feed straight from the battery to get it working properly.
Andy Sez....
F.Y.Y.F.F.
Whosthedaddy
PostPosted: 23:11 - 07 Nov 2007    Post subject: Reply with quote
The 7R had twin, yes twin air horns and kept blowing the fuses all the time as it was overkill big stylee. Got a little horn now so 'bip bip' Laughing
PostPosted: 23:24 - 07 Nov 2007    Post subject: Reply with quote
If you have wired the compressor directly through that poxy little switch on your handle bars - don't. Fit a relay, it's not difficult.
The last post was made 18 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 43.48 Kb
