Hi a Busa
MikeH
PostPosted: 21:46 - 08 Nov 2007    Post subject: Hi a Busa Reply with quote
Just thought I'd pop in and say hello, not been on here for quite a while. Sold the XJR about a month back and have just bought a 2001 Busa, needs some work as it's had a bit of a bump and is currently an unlicensed Cat C write off , bent forks, plastic damage, pipes etc but with a little work over the winter she'll be ready for the new year, bring it on Mr. Green
https://www.yamahaxjrownersclub.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=2695&g2_serialNumber=2
Busa Junkie
McGee
O RLY?
PostPosted: 23:07 - 08 Nov 2007    Post subject: Reply with quote
Should be fun Cool
Its pronounced Jixxer!
Whosthedaddy
PostPosted: 23:28 - 08 Nov 2007    Post subject: Reply with quote
McGee wrote:
Should be fun Cool
Hell yeah.
Sod getting the cosmetics sorted, just rip out the heart and ram it in the ass of a mini or Smart car Wink
MikeH
PostPosted: 23:33 - 08 Nov 2007    Post subject: Reply with quote
Whosthedaddy wrote:
McGee wrote:
Should be fun Cool
Hell yeah.
Noooo that's so wrong, you can't put a busa engine in a cage Laughing
Busa Junkie
McGee
O RLY?
PostPosted: 23:38 - 08 Nov 2007    Post subject: Reply with quote
You can and it gives some mental results Cool
Whosthedaddy
PostPosted: 23:39 - 08 Nov 2007    Post subject: Reply with quote
How much wonga for the Cat C?
jimbothe
PostPosted: 23:55 - 08 Nov 2007    Post subject: Reply with quote
"Noooo that's so wrong, you can't put a busa engine in a cage Laughing"
Watch this and tell me it wouldnt be at least a little fun Cool
https://www.youtube.com/watch?v=wi_CgGGDglY
Now that would be fun pulling away at the lights cage or not Laughing
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
MikeH
PostPosted: 23:56 - 08 Nov 2007    Post subject: Reply with quote
Two big ones
Busa Junkie
MaybeGuy
PostPosted: 00:07 - 09 Nov 2007    Post subject: Reply with quote
£11?? thats a bargain!
Whosthedaddy
PostPosted: 00:13 - 09 Nov 2007    Post subject: Reply with quote
MikeH wrote:
Two big ones
Thats less than the engine alone.
Well apart from turning the same shade as the hulk, nice one Thumbs Up
MikeH
PostPosted: 00:26 - 09 Nov 2007    Post subject: Reply with quote
Yeah seen it, cool but still a waste of of a good bike Wink
Busa Junkie
MikeH
PostPosted: 00:31 - 09 Nov 2007    Post subject: Reply with quote
Yep too good to miss huh Wink
Busa Junkie
MaybeGuy
PostPosted: 00:33 - 09 Nov 2007    Post subject: Reply with quote
ill give you a SRAD and a lifan for it Thumbs Up
MikeH
PostPosted: 00:40 - 09 Nov 2007    Post subject: Reply with quote
The second words off Middle Finger Mr. Green
Busa Junkie
MaybeGuy
PostPosted: 01:13 - 09 Nov 2007    Post subject: Reply with quote
go OFF and get your bikes and ill swap?
MikeH
PostPosted: 01:19 - 09 Nov 2007    Post subject: Reply with quote
Laughing Laughing Not even slightly warm Laughing Laughing
Busa Junkie
DEN MONKEY
PostPosted: 07:07 - 09 Nov 2007    Post subject: Reply with quote
I'm OFF to get papers for the trade see you soon ?
meh
PostPosted: 08:17 - 09 Nov 2007    Post subject: Reply with quote
Well done Mike Thumbs Up
Souns like you got a nice deal there and if you're patient you should be able to pick-up a complete bodykit for £400. If you need a left indicator I *might* have one - I'll have to check - they are £90 new.
EDIT: By the way, Suzuki didn't bring in any new 'busas in 2001 because they over-did it in 2000 and still had a years worth of bikes to shift. It's likely yours is an RX or RY model, with external fuel-pump and 220mph clocks.
PostPosted: 09:18 - 09 Nov 2007    Post subject: Reply with quote
Just noticed in your pic you got the battery hooked up to what looks like a normal charger. This will cook the battery - you'll notice the sides of the battery will bulge a bit - at which point it's knackered. If it was flat when you got it then it's knackered anyway. This is really important on a 'busa because starting one on a weak battery can cause the engine to kick-back which smashes the starter gear off the engine and usually wrecks the main engine cases where is wrenches the idler-gear shaft out of it's spigot. Best bet is to buy a new battery, or even better a Yuasa YTZ-14S which is more powerful and fits straight in.
PostPosted: 10:10 - 09 Nov 2007    Post subject: Reply with quote
*cough* turbo it *cough*. Wink
MikeH
PostPosted: 10:26 - 09 Nov 2007    Post subject: Reply with quote
It's got the restricted version clocks and the fuel pump is in the base of the tank so not sure although it comes up on the HPI as an RY ? as for the battery charger it's a switchable job with high and low ampage settings so no probs there, it wasn't competely flat as the guy had stored it disconnected so hopefully it's OK but obviously any doubt it'll be swapped Wink cheers for the headsup Thumbs Up
Busa Junkie
PostPosted: 10:35 - 09 Nov 2007    Post subject: Reply with quote
The restriction can be remove with a 6.8k resistor (If you really must go over 186mph), and the in-tank pump makes it a later model which is handy as the external-pump moels have a habit of clogging-up the 3 filters inside after 15k miles.
For the battery you should only use a charger like an optimate, the gel batteries are very easy to ruin. You might be lucky but the ods aren't good in my experience. Plenty of good technical advice over on 200mph.org Wink
Noxious89123
PostPosted: 00:24 - 10 Nov 2007    Post subject: Reply with quote
Bah, Smartukis... Everyones seen one.. Check this out!
https://uk.youtube.com/watch?v=CJgxMoDn8VA&NR=1
https://uk.youtube.com/watch?v=jiEC2_6jyvU
MikeH
PostPosted: 00:58 - 10 Nov 2007    Post subject: Reply with quote
Actually I was wrong, I had another look tonight while battling with the manifold studs, 3 hours to get the downpipes off !!!! Anyway, I think the pump is external so you we're on the money when you said it's a late registered early model. Got me worried now as I've read a few things about the 99/00 models having cam chain tensioner issues ?
Also found a bit more damage tonight, the sprocket cover casing where the clutch slave mounts is split, something else for the shopping list
Neutral
Not too worried about derestricting it just yet Wink
Mike Cool
Busa Junkie
MaybeGuy
PostPosted: 01:14 - 10 Nov 2007    Post subject: Reply with quote
oh god damn, its worth less than a SRAD now with that split...
wanna trade?
The last post was made 18 years, 284 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 136.88 Kb
