| TUBZ69 |
 TUBZ69 Trackday Trickster
 Posted: 15:47 - 12 Nov 2007 Post subject: j1 zx6r startup probs |
charged up the battery 2day to start the zx for the 1st time in bout 8 months (crash rebuild) eveythin seemed ok, alarm, dash etc all as normal. went to turn her over an all i got was just this faint 'machine gun like' sound from under neath the tank in the enginebay, this eventually died?
any ideas??
starter motor had it?
duff battery charger? ( ive had battery die on the gsxr an sounds the same as it did then wen i tryed to start it, so prehaps the charger is buggered? an hence battery has no power)
i drained the tank. an put fresh fuel in by the way..
T  ____________________ those who risk nothing, become nothing, achieve nothing....
c90 rvf 400, vfr 400, gpz 500, Gsxr 750, R1, Zx6r.... |
| TUG |
 TUG World Chat Champion
| TUBZ69 |
| TUBZ69 |
 Posted: 18:04 - 12 Nov 2007 Post subject: |
oive bin a donkey.....
its the car charger that i was usin, so hasent actually chardged the batery to any real level.... brilliant..... need more sleep i think
| G |
 G The Voice of Reason
| TUBZ69 |
 Posted: 18:44 - 14 Nov 2007 Post subject: |
ok, batterys fine now, the main problme was i forgot to connect a plastic connector underneath the clutch lever! it hasent fired into life yet but the engine is now turnin over, an huffin a n puffin out of the exhaust a little, 2 BIG BANGS as well with flames! but i think i ran the battery down a bit to much fannyin about with it b4 i found the connection that i hadnt ut together, turnin the alarm on an off etc....
il charge the battery to max again an try 2mora
| TUBZ69 |
 Posted: 19:53 - 15 Nov 2007 Post subject: |
right , it now starts an sounds sweet, BUT:
although it sounds purposeful it also sounds pretty friggin lumpy, burbley etc, it comes up to temp fine. i ran it to 100 c an ther were no leaks but it wont idle, if i let go of the throttle it dies, but starts again fine?.....
it now has a full titanium race system (leo vince) an it hasent bin set up at all yet , (b4 the crash it was standard apart from a remus end can) and it has bin sittin for about 8 months (with the carbs an airbox off) without being started, so carbs are probly a little out of shape anyways so that wont help....
wot happens to carbs wen there left sittin incidently, do they collect moisture or?
any ideas peeps?
thanx  ____________________ those who risk nothing, become nothing, achieve nothing....
| TUG |
| Phil_P |
 Phil_P Trackday Trickster
| TUBZ69 |
| TUG |
| TUBZ69 |
 Posted: 15:32 - 16 Nov 2007 Post subject: |
| XlonewolfX wrote: | is your cable routing correct? forgot how mine went and it did the same. if your thinking of lubeing the cables up use some red grease, as is good for cables, WD-40 makes the cable wrap swell. |
yea i thought i mite have done sumthin like that to be honnest, i woudlnt know though, without lookin at another bike....
pics anyone ? ____________________ those who risk nothing, become nothing, achieve nothing....
| TUG |
| TUBZ69 |
| TUG |
| TUBZ69 |
 Posted: 17:57 - 17 Nov 2007 Post subject: |
ok started it again a minute ago, started up no probs, all the manifold pipes are the same temp, no probs there, i havent tryed to turn the bars an see if it revs, but will do asap... il haveto have a look at the throttle asembly on the carb itself, an give it a good old clean! ____________________ those who risk nothing, become nothing, achieve nothing....
The last post was made 18 years, 222 days ago. Instead of replying here, would creating a new thread be more useful? |
