bandit 600 playing up
TERRYREBEL
PostPosted: 05:51 - 15 Nov 2007    Post subject: bandit 600 playing up Reply with quote
hi during the day my bike the bandit 600 runs fine but lately coming home from work in the cold night after 2 - 3 minutes of riding its seems to wanna cut out at low revs i dunno what it could be my mechanic reckons carb icing but im not sure any 1 got any ideas cheers please help
Did have a Bandit 600 now i have another 1 lol i love the bandit
Kris
PostPosted: 09:16 - 15 Nov 2007    Post subject: Reply with quote
do a google search for carb icing. I bet that's what it is.
www.prisonplanet.com
PostPosted: 10:11 - 15 Nov 2007    Post subject: Reply with quote
+1 for carb icing. You can get additives for your fuel that dissolves the ice as soon as it forms, try putting some of that through.
doggone
PostPosted: 11:15 - 15 Nov 2007    Post subject: Reply with quote
It's not cold enough for carb icing yet.
Could be carbs need balancing.
Kris
PostPosted: 11:31 - 15 Nov 2007    Post subject: Reply with quote
Depends where he is in the world, don't ya think?
Rolling Eyes
Out in the sticks or 'oop North' I can easily see it being cold enough at night.
Gazdaman
I did a trackday!!!
PostPosted: 11:49 - 15 Nov 2007    Post subject: Reply with quote
It's definitely cold enough for carb icing. My bandit would do it if I rode in the shadows in the summer.
You want some proFST fuel additive, whack it in with your petrol and all will be good.
People do say a bit of surgical spirit does the same thing, and will certainly be cheaper.
Gaz
PostPosted: 12:32 - 15 Nov 2007    Post subject: Reply with quote
Carb icing doesn't need it to be that cold. If it gets cold enough then it ceases to be a problem. Perfect conditions are low temps around zero and damp air (if it gets too cold and there ceases to be enough moitsure in the air to cause a problem). Generally will be OK at low speeds / revs where the heat has a chance to soak into the carbs and the air speed / volume through the carbs is reduced (so getting stuck in traffic tends to fix it).
Bandit should have electric carb heaters (most of the 600s anyway). Check they haven't become disconnected.
Trying an additive might be worthwhile to see if it fixes the problem.
However should say that carb icing is not as common as some people think.
TERRYREBEL
PostPosted: 14:17 - 15 Nov 2007    Post subject: thanx Reply with quote
thanks for the replys guys and yes im a noob
ryder_bandit
PostPosted: 20:33 - 15 Nov 2007    Post subject: Reply with quote
my 600 bandit doing exactly the same thing,i reckoned carb icing too.whats the best additive then?
Gazdaman
I did a trackday!!!
PostPosted: 22:06 - 15 Nov 2007    Post subject: Reply with quote
ryder_bandit
PostPosted: 22:23 - 15 Nov 2007    Post subject: Reply with quote
woops!!should read things properly
cheers mate
The last post was made 18 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 68.24 Kb
