| TERRYREBEL |
 TERRYREBEL Nova Slayer
| Kris |
 Kris World Chat Champion
 Posted: 09:16 - 15 Nov 2007 Post subject: |
do a google search for carb icing. I bet that's what it is. ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 10:11 - 15 Nov 2007 Post subject: |
+1 for carb icing. You can get additives for your fuel that dissolves the ice as soon as it forms, try putting some of that through. ____________________ My Flickr |
| doggone |
 doggone World Chat Champion
| Kris |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Kickstart |
 Kickstart The Oracle
 Posted: 12:32 - 15 Nov 2007 Post subject: |
Carb icing doesn't need it to be that cold. If it gets cold enough then it ceases to be a problem. Perfect conditions are low temps around zero and damp air (if it gets too cold and there ceases to be enough moitsure in the air to cause a problem). Generally will be OK at low speeds / revs where the heat has a chance to soak into the carbs and the air speed / volume through the carbs is reduced (so getting stuck in traffic tends to fix it).
Bandit should have electric carb heaters (most of the 600s anyway). Check they haven't become disconnected.
Trying an additive might be worthwhile to see if it fixes the problem.
However should say that carb icing is not as common as some people think.
| TERRYREBEL |
| ryder_bandit |
 ryder_bandit Renault 5 Driver
| Gazdaman |
| ryder_bandit |
The last post was made 18 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
