Is this snakeoil?
PostPosted: 07:09 - 16 Nov 2007    Post subject: Is this snakeoil? Reply with quote
https://cgi.ebay.co.uk/15HP-O2-SENSOR-PERFORMANCE-CHIP-TRIUMPH-DAYTONA-600_W0QQitemZ110193419780QQihZ001QQcategoryZ10486QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Seems to have good feedback.
Chriss
PostPosted: 07:59 - 16 Nov 2007    Post subject: Reply with quote
I've no conclusive proof, but as I've seen them advertised for every kind of vehicle, I'm going for bollocks.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
PostPosted: 09:48 - 16 Nov 2007    Post subject: Reply with quote
It probably works, but it probably works by making the bike run stupidly rich or something.
Engine damage ensues! Or at the very least, a coked up valve or two!
Avoid.
MattEMulsion
PostPosted: 11:03 - 16 Nov 2007    Post subject: Reply with quote
I wouldn't touch it if it was me.
Yamaha YZF-R6
feef
Energiser Bunny
PostPosted: 11:11 - 16 Nov 2007    Post subject: Reply with quote
it's an inline resistor.
can be bought for a couple of pence from Maplin if you know the resitance required.
Makes the bike run a little richer.
as a rule, if you have to ask if it's snake oil, it probably is.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
lilredmachine
PostPosted: 13:52 - 16 Nov 2007    Post subject: Reply with quote
Having said that, it probably will work as most bikes are horribly lean from the factory to hit emissions targets.
PostPosted: 18:36 - 16 Nov 2007    Post subject: Reply with quote
There's no way you are going to get 15hp on anything by modifying the O2 sensor circuit. Most bikes only use the sensor for closed-loop fuelling at low output levels anyway then switch to open-loop for heavy loads.
Think about it - you cannot pick up 15hp by fitting a £300 powercommander an £250 can so if this thing worked then Dynojet would have ceased tradig by now.
loply
PostPosted: 19:05 - 16 Nov 2007    Post subject: Reply with quote
It's worth a small improvement in power on certain bikes, in certain conditions.
Not a universal rule by any means though.
15% sounds a tad optimistic, more like 3hp on a typical 600 afaik.
Yamaha SZR660 Caution to the wind, the throttle pinned!
cagiva gezzer
PostPosted: 19:40 - 16 Nov 2007    Post subject: Reply with quote
As above, at WOT the lambda sensor is not used, so it won't alter the running.
At part throttle you'll run richer and have bore wash.
The last post was made 18 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 61.41 Kb
