vfr400
garyd
PostPosted: 20:41 - 16 Nov 2007    Post subject: vfr400 Reply with quote
Just bought vfr400 (nc21) any thing i should look for ,??going to give it a good look over tomorrow,anything peculiar to this model?runs nice,what oil and how much ?where is oil filter ?is body work easy to remove ?or will lugs break etc,thanks Smile
Odie
PostPosted: 20:55 - 16 Nov 2007    Post subject: Re: vfr400 Reply with quote
garyd wrote:
Just bought vfr400 (nc21) going to give it a good look over tomorrow,
Should of done that before you brought it!
You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat."
garyd This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
garyd
PostPosted: 23:47 - 16 Nov 2007    Post subject: Reply with quote
Well the actual post was aimed at vfr owners,i am technically savvy ,just bikes have quirks and no better person to ask than an owner ,which obviously aint you
Kiss_My_Rs
PostPosted: 00:49 - 17 Nov 2007    Post subject: Reply with quote
Just a genral all over check.
All depends on what the last owner did.....!
I would start with a complete fluid change.
Coolant, oil, brake fluid etc
Check the valve clearance and adjust as required.
Check the rear hub and swingarm for play.
Also i suggest removing the rear wheel and giving it a good coat of copper grease on the hub.
Http://www.manchesterbikers.net
The last post was made 18 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.30 Sec - Server Load: 10.99 - MySQL Queries: 13 - Page Size: 43.18 Kb
