spark plug
td007
PostPosted: 16:16 - 19 Nov 2007    Post subject: spark plug Reply with quote
my spark plug just blew up in my gilera dna ok but the threded end of the spark plug is still in my engine the rest of it shot out
why did this happen does anyone know
also what can i do to fix it thanks
Sad urgent[/b]
TUG
PostPosted: 16:22 - 19 Nov 2007    Post subject: Reply with quote
what Shocked does the bike still turn over? i would think to get the rest out you would need to take the head to a mechanic so he can get the thread out.
Haz ER-5, innit!
td007
PostPosted: 16:27 - 19 Nov 2007    Post subject: Reply with quote
yes still turns over
TUG
PostPosted: 16:28 - 19 Nov 2007    Post subject: Reply with quote
i dont know what you could do other than take it to a mechanic, if you cold post some pics up on here that would be great.
Haz ER-5, innit!
PostPosted: 16:29 - 19 Nov 2007    Post subject: Reply with quote
Could have been overtightened when it was put in. Could be corrosion from being in there a long time. Could be a faulty plug.
If you are confident what you are doing, I'd try an ez out on it. It's a thin thread and a big ez out.
If it's a 2-stroke, I might even try whipping the head off and tapping the thread remnant round with a punch.
If you think there is any chance of either breaking the extractor or dropping something into the engine, stop and take it to a professional.
If it's a 2-stroke. Worst case a new head costs about £45. A 4-stroke head would be more expensive and harder to fit.
TUG
PostPosted: 16:31 - 19 Nov 2007    Post subject: Reply with quote
tis a 2 stroke stinkwheel. Thumbs Up i would take it to a professional, or remover the head and see if i could unscrew it from the other side (chamber side) good job it is a 2 stroke Thumbs Up
Haz ER-5, innit!
td007
PostPosted: 16:41 - 19 Nov 2007    Post subject: Reply with quote
it a four stroke 125 will it tell me in my workshop manual how to get the head off
TUG
PostPosted: 16:43 - 19 Nov 2007    Post subject: Reply with quote
Doh! am sure my eyes are gone, i swore i read 50 after DNA.
Haz ER-5, innit!
PostPosted: 16:50 - 19 Nov 2007    Post subject: Reply with quote
This is not such a minor job as removing the head on a 2-stroke.
I'd take the whole thing to an engineer, they might be able to extract the remaining bit without removing the head.
I've sucessfully removed sheared sparkplug threads before using EZ outs (greased, wiped regularly then regreased to stop swarf dropping down into the engine).
As I say, less likely to shear the extractor than normal because it is such a thin section of thread with such a large extractor and you are definately screwing it down the dead centre of the stuck bit.
td007
PostPosted: 16:54 - 19 Nov 2007    Post subject: Reply with quote
where can u get the ez out things
Cigaro
PostPosted: 17:00 - 19 Nov 2007    Post subject: Reply with quote
Surely removing the head can't be that big a job? Obviously the valvetrain drive gear will have to come off but with the aid of a workshop manual and proper tools I can't see it being that bad.
TUG
PostPosted: 17:19 - 19 Nov 2007    Post subject: Reply with quote
manual here covering all the gilera models upto 04 if you need info Thumbs Up
Haz ER-5, innit!
Barry_M2
PostPosted: 17:37 - 19 Nov 2007    Post subject: Re: spark plug Reply with quote
Sad urgent[/b]
The thread of the plug will more than likely be still screwed into the head.
The rest would have just blown out the top. I doubt there is any leftover bits in the barrel, but you never know!
To get the thread out you can tap in a screwdriver to grip the inside of the thread from the plug, and try and swist it out. I had to go this when one of my plugs decided to to the same, although this was when I was tightening it up rather than with the engine running.
(And no, I didn't over tighten it!)
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
Finglonga
PostPosted: 17:38 - 19 Nov 2007    Post subject: Re: spark plug Reply with quote
Sad urgent[/b]
Where did it break off? Do you mean the insulator has broken off or it has snapped below the nut?
Andy Sez....
F.Y.Y.F.F.
PostPosted: 18:07 - 19 Nov 2007    Post subject: Reply with quote
I presumed he was meaning the plug had broken round where the hex joins onto the thread. Whenever I've had this happen before, all the rest of the plug has come away in one piece leaving you with just a 'collar' of steel thread screwed into the head, seems to be a weak point.
Is this correct?
td007
PostPosted: 18:11 - 19 Nov 2007    Post subject: Reply with quote
yes just the threded bit left in the head
i will get u a picture later if u can upload them on here
td007
PostPosted: 18:50 - 19 Nov 2007    Post subject: Reply with quote
https://i188.photobucket.com/albums/z117/trist077/DSC00022.jpg
this is the spark plug if this is a better idea
Barry_M2
PostPosted: 20:49 - 19 Nov 2007    Post subject: Reply with quote
Looking at that picture, I think there may well be some of the ceramic insulator on top of the piston! Shame, as it means the head has to come off.
I wouldn't turn it over any more either if I were you.
holyman
PostPosted: 22:54 - 19 Nov 2007    Post subject: Reply with quote
get it to a mechanic. Removing a 4 stroke head is fairly invlolved for a novice.
Phil_P
PostPosted: 09:52 - 20 Nov 2007    Post subject: Reply with quote
Although involved, if you want to learn about working on your bike, I can't think of a better time to do it. If you can get a manual and are fairly adept with your hands you CAN do the work yourself.
When I started messing with bikes (four strokes incidentally), I taught myself by doing things. I would never have dreamed of taking a bike to a mechanic for dismantling, if for no other reason than I didn't have the money available.
I am pleased for those that have enough disposable income to hand over problems to someone else to sort, but to me, a large part of being a motorcyclist is getting my hands dirty and having the reward of making my bike work again by my own labour.
I realise that there are some for whom, being their own mechanic is a no-no, but please guys, don't scare off the younger less experienced members of the forum who would like to give it a go by throwing your hands in the air and saying 'take it to a mechanic'.
If the plug has broken off so that the washer has come free, then there won't even be any torque still holding the remains in place, so it should only be finger tight. Push a largish screwdriver into the bit that's left, give it a light tap with a hammer and the chances are that it will unscrew quite easily.
Ask around for a friend or relative to lend a hand or just point you in the right direction, and I'll bet you can do the head off bit yourself too. Save yourself a fortune and know the job's been well done.
It is not enough to win, others must fail.
Moto Guzzi 1100 Sport Injection '96
td007
PostPosted: 11:43 - 20 Nov 2007    Post subject: Reply with quote
me and my next door neibough are goin to have a look at later as next door has done some mechanics before and i am willing to learn how to do things
were going o try and get it all out in one piece if we can e.g. the thread and the remaining bit of rod that sparks at the end
if goes as planned ok i think if not gonna work how to get the head off in the manual and clean the engine of the remaining bits
hopfully we will get there
Phil_P
PostPosted: 14:23 - 20 Nov 2007    Post subject: Reply with quote
Good for you, don't be put off. Thumbs Up Thumbs Up Thumbs Up Work steadily and methodically. If you have a digital camera, take photos as you go of anything that might be confusing on re-assembly. Lay out the parts you take off in a logical way. If you put down parts on pieces of paper, you can write down where they are from.
Can be handy to get things like gaskets in advance so you can put it back together without any delays.
td007
PostPosted: 16:52 - 20 Nov 2007    Post subject: Reply with quote
bought a tap and die kit today and goin to see if the rest of spark plug will come out first if all fails then the head will come off
the neibough has not had a look today hes not had time so goin to have a go myself
also its hard place to get to, striped the dummy tank out etc cant work out how to drop the fuel tank out for easier access or weather to drop the engine out and do it can anyone help i cant find it in the manual thanks
feef
Energiser Bunny
PostPosted: 17:22 - 20 Nov 2007    Post subject: Reply with quote
a tap and die kit will not help you get the remains of the thread out.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
Barry_M2
PostPosted: 17:29 - 20 Nov 2007    Post subject: Reply with quote
Yeah, what you should have got was a spark plug thread chaser.
The last post was made 18 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 130.13 Kb
