ignition timing
infostrada
PostPosted: 20:20 - 19 Nov 2007    Post subject: ignition timing Reply with quote
how do u set up the ignition timing on my mito?? iv had to swap coils because i damaged one screwing the bolts in too far as it is my first time removing the flywheel
mitooooooooooooooooomadmann
infostrada
PostPosted: 22:04 - 19 Nov 2007    Post subject: Reply with quote
take it nobody noes
holyman
PostPosted: 22:50 - 19 Nov 2007    Post subject: Reply with quote
why are you taking the flywheel off?
which coil did you damage?
generally you'd set the timing using a strobe light connected to the HT lead and pointed at the timing mark on the flywheel. Then you'd adjust the stator plate holding the ignitor pickup to get the mark in the light.
PostPosted: 23:15 - 19 Nov 2007    Post subject: Reply with quote
There is (from memory) a special tool for setting the timing on the Mito. Not sure of an easy way to do it otherwise, beyond playing around with a strobe light.
Paddy Blake
PostPosted: 23:27 - 19 Nov 2007    Post subject: Reply with quote
The lad that posted the picture of how to get the flywheel off can also be
found on the 125 site and you can do a search there for more info. Thumbs Up
https://www.125ccsportsbikes.com/forums//index.php?s=6e73cfec2d95d3b1d70a907b213e8868&act=idx
Paddy.
infostrada
my bro got us banned from that forum
Paddy Blake
PostPosted: 23:34 - 19 Nov 2007    Post subject: Reply with quote
I think I have the manual,I'll have a look.
Paddy.
infostrada
PostPosted: 23:39 - 19 Nov 2007    Post subject: Reply with quote
and holyman i had to take the flwheel off to replace a gasket that fits on a casing behind the flwheel and i swapped the coil over as i thougth might aswell while the flyweel as the flywheel is off
holyman
PostPosted: 23:41 - 19 Nov 2007    Post subject: Reply with quote
this is the ignition coil that sends HT to the plug or the pickup coil?
infostrada
PostPosted: 23:42 - 19 Nov 2007    Post subject: Reply with quote
the stator plate behind the flywheel
holyman
PostPosted: 23:43 - 19 Nov 2007    Post subject: Reply with quote
ah ok so that is why you need to check the timing. gotcha. that is the pickup coil.
Paddy Blake
PostPosted: 23:44 - 19 Nov 2007    Post subject: Reply with quote
Mito MK2 Manual 4MB Page 90.
https://www.mmra.org.uk/marci/mito/others.php
Paddy.
infostrada
PostPosted: 23:45 - 19 Nov 2007    Post subject: Reply with quote
wish i never touched the stator plate now im fuked rite off
holyman
PostPosted: 23:52 - 19 Nov 2007    Post subject: Reply with quote
right...read that......at 1mm before TDC the stator plate lines up with a mark on the crankshaft. but you don't have the tool right?
are there any timing marks on the flywheel?
cagiva gezzer
https://i67.photobucket.com/albums/h294/supercitybity/Cagiva/Cagiva8.jpg
Put the stator plate on as above. That'll get you about right, however you should of marked the old one before taking it off.
infostrada
PostPosted: 23:55 - 19 Nov 2007    Post subject: Reply with quote
i thought it has to be axactly rite and how do i no when its 1mm
holyman
PostPosted: 23:58 - 19 Nov 2007    Post subject: Reply with quote
that's what the dial gauge would tell you, but you could use the old old way of a pencil down the spark plug hole. But to be honest your best bet is someone who has the right tools.
infostrada
PostPosted: 00:05 - 20 Nov 2007    Post subject: Reply with quote
wots that tool on the manual
Paddy Blake
PostPosted: 00:18 - 20 Nov 2007    Post subject: Reply with quote
A dial gauge.
Paddy.
infostrada
PostPosted: 09:50 - 20 Nov 2007    Post subject: Reply with quote
not the one in the head thats the dial gauge aint it i mean the other one
1016
PostPosted: 03:37 - 01 Dec 2007    Post subject: mito timing Reply with quote
You must mean the one you use to set up the stator plate (Tool 48803) You will need to buy or borrow this tool from someone to time it properly. It fits on the crank and locates on the woodruff key. The notched mark on the top of this tool (at about 12 oclock) must line up with a similiar notch on the stator plate (roughly in the centre of the top coil) when the piston has travelled 1 mm* down the bore. *This figure can vary depending on which engine
The last post was made 18 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 104.1 Kb
