If i stubby my can
Damon
PostPosted: 18:18 - 24 Nov 2007    Post subject: If i stubby my can Reply with quote
will i have to mess about with the fueling to get it running properly. im looking to take about two inches off. will this affect my bike at all.
Cheers all Smile Thumbs Up
PostPosted: 18:20 - 24 Nov 2007    Post subject: Reply with quote
It might - you'll have to do the mod to find out. Do a plug-chop afterwards to check the WOT fuelling.
Damon
PostPosted: 18:31 - 24 Nov 2007    Post subject: Reply with quote
is their any easier ways to determine other than a plug chop. Seems like a lot of work and i dont like the idea of butchering perfect new plugs.
Thanks
PostPosted: 19:10 - 24 Nov 2007    Post subject: Reply with quote
Thanks
Very Happy Very Happy
Sorry buddy but that made me smile. A plug-chop does no harm to the plug at all and in fact should be done with a new spark plug fitted.
Ride along at full throttle for a bit (1/2 mile or so), then chop the throttle and pull-in the clutch, then kill the engine and coast to a stop. Now remove one of your plugs and look at the colour to determine what your mixture is at full throttle.
Finglonga
PostPosted: 19:41 - 24 Nov 2007    Post subject: Reply with quote
. . . . Then get a big axe . . . . Wink
Andy Sez....
F.Y.Y.F.F.
hmmmnz
PostPosted: 20:14 - 24 Nov 2007    Post subject: Reply with quote
hehehehe lol funny stuff Very Happy
the humans are dead
I kick arse for the lord
lllN30lll
PostPosted: 20:18 - 24 Nov 2007    Post subject: Reply with quote
Thanks
that's proper Sig material but i've got no room.
Turbo R1
CRF450R
PostPosted: 23:55 - 24 Nov 2007    Post subject: Reply with quote
LukeVFR wrote:
I cut my R6's Micron can in half, and it didn't affect performance what-so-ever,
Isn't your bike fuel-injected? It would have less of an effect than his little stroker.
Damon
PostPosted: 00:40 - 25 Nov 2007    Post subject: Reply with quote
lol my bad, Wink
dont i have to cut the thread down to the base and see if there is a brown coloured line on the plug?
Nb
PostPosted: 10:19 - 25 Nov 2007    Post subject: PLUG CHOP Reply with quote
Confirm your jetting with plug chops
A plug chop simply means looking at the sparkplug to determine how you are jetted at a particular throttle stage. The only tricky part is in isolating the throttle stage. Before starting, clean your sparkplug and filter and warm the bike up.
To check the main jet, which operates from 1/2 to full throttle, get the scooter up to a steady full throttle or near to it for a good few seconds, then simultaneously pull in the clutch and kill the engine. Don't let the motor drag you to a stop, or fall to an idle, because you want to isolate the plug color at full throttle.
Get off and check the sparkplug color. (Links on our tech page.) It should be a light chocolate color. If it's white, the air/fuel mixture is too lean and you need a bigger main jet. If it's black or really dark brown, the air/fuel mixture is too rich and a smaller main jet is needed. If you need to change jets, change by one size, and do another run.
No cutting tools needed. Laughing
Take a look here also, https://www.dansmc.com/EXHAUST_2.htm
My advice? Leave the bloody thing alone before it goes bang. Wink
PostPosted: 10:28 - 25 Nov 2007    Post subject: Reply with quote
I'd have said that Aprilia spend millions of pounds of development on two stroke exhausts, which are MUCH more essential for performance than on four strokes.
The cans are tiny anyway, so why you would want to stubby it I'll never know.
And LukeVFR, you say your bike's performance has not been affected? How can you tell? Have you dynoed it before and after the mod?
I reckon most people wouldn't notice a 10bhp difference in a 600, especially if the bike is louder to boot...
Damon
PostPosted: 11:23 - 25 Nov 2007    Post subject: Reply with quote
[quote="MarJay"]I'd have said that Aprilia spend millions of pounds of development on two stroke exhausts, which are MUCH more essential for performance than on four strokes.
[quote]
I just would like something thats custom to me. quite like the idea of a tiny can.
I was gonna buy an arrow can anyway, but thought i could stubby the original can, and if it goes tits up, then buy the arrow can.
Does stubbying a can typically mke it run rich or lean?
Thanks all Thumbs Up
Finglonga
PostPosted: 11:37 - 25 Nov 2007    Post subject: Reply with quote
If you don't do it right the first time the "going tits up" bit may be a seize or a holed piston. Shocked Is it worth taking the chance?
Andy Sez....
F.Y.Y.F.F.
Damon
PostPosted: 11:40 - 25 Nov 2007    Post subject: Reply with quote
Finglonga wrote:
If you don't do it right the first time the "going tits up" bit may be a seize of a holed piston. Shocked Is it worth taking the chance?
shit really? I thought it would make a minimum of difference. Is there anything i could do that wouldnt result in a siezed piston? change the jetting etc? Thumbs Up
Thanks all
Philious
PostPosted: 11:53 - 25 Nov 2007    Post subject: Reply with quote
Lol yeah your sig is jam packed, I thought we was only meant to have 3 lines?
Thinking
Erm how about leaving it standard and just being happy with it as it is. Thumbs Up
Previously; Honda XR125 - Yamaha DT125r - Aprilia Rs125 - Suzuki GS500e, Currently; Kawasaki ZX6R + ZX10R
Theory : Passed 28/7/09 Module 1: Passed 21/09/09 Module 2: Passed 23/09/09
PostPosted: 14:57 - 25 Nov 2007    Post subject: Reply with quote
Thanks all
No, it could result in a holed piston. Which is worse. Parts of the piston may be flung about inside the engine causing all sorts of untold damage.
It isn't worth it IMO.
Finglonga
PostPosted: 15:54 - 25 Nov 2007    Post subject: Reply with quote
Thinking
Thats the size of your tiny tiny screen, lllN30lll's sig is only 1and a half lines with me. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
01dabreoo
PostPosted: 15:58 - 25 Nov 2007    Post subject: Reply with quote
Cans on 2 stokes make very very little difference, would be fine running without one imo.
Damon
PostPosted: 16:37 - 25 Nov 2007    Post subject: Reply with quote
? how come you are telling me this but ive just been told the opposite in the above thread?
ahhh who to believe.... ahhh im going to start talking to myself in a minute. Wink
01dabreoo
PostPosted: 17:12 - 25 Nov 2007    Post subject: Reply with quote
2 stokes get all their back pressure from the expansion chamber, the cans are purely just to make them quieter.
Damon
PostPosted: 22:00 - 25 Nov 2007    Post subject: Reply with quote
so i can stubby the can with not ill effects?
just to clarify Thumbs Up
01dabreoo
PostPosted: 22:03 - 25 Nov 2007    Post subject: Reply with quote
I believe it wont Razz
Chriss
PostPosted: 22:15 - 25 Nov 2007    Post subject: Reply with quote
See my dyno results for what happens when you put a set of stubby cans on a bike. I lost around 7 peak hp from stock, but loads over all, and it was running wwaaaaayyyyyy lean.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
NSR Mick
PostPosted: 22:23 - 25 Nov 2007    Post subject: Reply with quote
Is 2 inches really worth the effort?
By all means go for it as it wont affect your mixture that much.
PostPosted: 22:36 - 25 Nov 2007    Post subject: Reply with quote
I stubbied my can this week - I wonder what effect it will have?
The last post was made 18 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 133.18 Kb
