| staxbrix |
 staxbrix Borekit Bruiser
 Posted: 23:16 - 25 Nov 2007 Post subject: |
First explain what you are trying to do and to what.
You've put a lighting circuit up from what looks like an Uber basic bike.
You have then asked about doing something to a bike with apparently different wiring colours to those shown on the diagram. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| staxbrix |
| teampots |
 teampots Spanner Monkey
| Polarbear |
 Polarbear Super Spammer
| Ichy |
 Ichy World Chat Champion
 Posted: 23:34 - 25 Nov 2007 Post subject: |
The circle is an earth point.
The red wire is the main positive power feed from the magneto, if you want a back light then the wire does need that split. Your magneto probably only has two wires since it earths from the mounting?
EDIT: Well thats three of us, guess its an earth point  |
| staxbrix |
 Posted: 23:43 - 25 Nov 2007 Post subject: |
Just a ground then, So splice into the black wire and connect it to a bolt with another black wire. It looks like I can unattach the other end and then run it to the light and ground it in the middle instead off at the bottom. SO theres no cutting off wire, Ill have to look on the bike.
Any Ideas about the the red wire. Do I only have to run it into the Switch? Nevermind you guys are quick.
Im not sure its a pretty basic elelctric system. Should I connect Y to y/b or red? ____________________ NFL Access: Sport News,Videos,Blogs
Motorcycle Trader: Sell,Buy Bikes
Screw Myspace: Sell Music Here |
| staxbrix |
 Posted: 00:12 - 26 Nov 2007 Post subject: |
It s the kdx200 88, Yeah there two wires thats come out the head and they have a plug looking cover over them.
Its been getting dark around 4pm lately and I want to be able to ride to at least 6pm. The housing and lights f0r my bike were too much. So I got a standard light that I can mount. I didnt realize they had wired my bike retarded.
I took a 9v battery and it made the light glow orange. I can get a small atv battery to power it by itself. But that would require alot of charging and shorter use. I could upgrade the light then, currently it only puts out 30-35 watts. With a battery I could get a 50-60 watt bulb in there. ____________________ NFL Access: Sport News,Videos,Blogs
 Posted: 00:20 - 26 Nov 2007 Post subject: |
Your bike is probably wired correctly. You said the diagram is for an '89 bike and the bike is an '88 model.
There is every chance they changed it.
You'll probably find you need to make up 40W somehow (going by the diagram) Any lower and you'll pop bulbs all the time, any higher and it'll be too dull. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| staxbrix |
 Posted: 00:38 - 26 Nov 2007 Post subject: |
What I meant is there should be wires in place to hook the light up near the stearing. Instead of rewiring and rerouting stuff.
I dont think theres a difference in the wiring. THe main difference was forks and radiator. But either way everything is exact as in the diagram except the color of the wires, Theres no other possible connection unless I run my own wire all the way to the magneto my self. And that would be pointless since theres a hook up already there. ____________________ NFL Access: Sport News,Videos,Blogs
 Posted: 00:49 - 26 Nov 2007 Post subject: |
See. This is exactly what I'm talking about. You need to explain what you're doing properly.
Where EXACTLY are these wires you're talking about connecting your light to? I assumed from your description they were coming from the magneto. Your last post suggests to me they are lurking around elsewhere.
According to your wiring diagram a yellow on black wire near the headstock or under the tank would be carrying the low tension spark from the CDI so leave that alone. I don't know about the red. Does the bike have the switchgear fitted? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| staxbrix |
The last post was made 18 years, 332 days ago. Instead of replying here, would creating a new thread be more useful? |
