What size compressor
AJ
PostPosted: 00:43 - 26 Nov 2007    Post subject: What size compressor Reply with quote
Hi all just wondering what size compressor is needed to seat the beads on the rims. Ie tank size maximum psi etc.
I dont want to buy a huge industrial one if it's not needed. All input is greatly appreciated thanks AJ
PostPosted: 00:57 - 26 Nov 2007    Post subject: Re: What size compressor Reply with quote
25 litres should be ok and be a reasonable size. Much smaller and it's either not that powerful or the compressor bit is just as big anyway.
Most 25 litres ones I've seen have been a fairly similar spec.
AJ
PostPosted: 15:43 - 26 Nov 2007    Post subject: Reply with quote
Thank's 4 that G appreciate it. Thumbs Up
tatters
Exxon Valdez
PostPosted: 16:18 - 26 Nov 2007    Post subject: Reply with quote
its not size that counts when seating the bead you need pressure make sure its got a max pressure of at lest 140-150 psi
Jamie S
PostPosted: 19:17 - 26 Nov 2007    Post subject: Reply with quote
25 Ltr's will get a tubeless tyre back on the rim easily ,having large bore Air hoses helps as well.
PostPosted: 19:27 - 26 Nov 2007    Post subject: Reply with quote
And connectors
Ichy
PostPosted: 20:19 - 26 Nov 2007    Post subject: Reply with quote
Not 100% true, you can get a low volume compressor that will get 150psi but will take all day to do it whereas a 2hp 50ltr hobby compressor will have a maximum working pressure of about 110-120psi but will sit the bead in no time. Size (volume) is very important, seating a bead wastes a lot of air, theres no point if you run out of in seconds. Its CFM that counts.
6CFM on a 25 litre tank, about 1.5 HP motor, just about did it on a 130/90 tyre with a bit of coaxing.
8-9CFM with a 50 litre tank, at least 2hp motor, does it easy.
AJ
PostPosted: 00:14 - 28 Nov 2007    Post subject: Reply with quote
Oh well I've gone and bought one now so hopefully it will do the job. Maximum tyre size I got to contend with is 150/70 17
The compressor is a 24 litre 1.5 kw 8bar 208 litres a minute
roughly coverted to Ichy's figures at 2hp motor max 117psi with a approx 7.4 cfm.
Did not cost a fortune just hope it seats the beads.
Thanks for all the input AJ Thumbs Up
Ichy
PostPosted: 12:03 - 28 Nov 2007    Post subject: Reply with quote
It should do it easy. The hardest bit is sealing any gaps, bit hard to explain but I find that sitting on the tyre to make it spread helps when I have a awkward one.
Phil_P
PostPosted: 14:45 - 28 Nov 2007    Post subject: Reply with quote
A ratchet strap all the way around the tread of the tyre can be used to squeeze the tyre to get an initial seal before blowing air in. When you are trying to initially seat a tyre, it is an idea to leave the valve out the wheel too, as getting air in quickly is important, at least it is on a tubeless.
It is not enough to win, others must fail.
Moto Guzzi 1100 Sport Injection '96
The last post was made 18 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 63.28 Kb
