Non standard bulb in a standard bike?
Whosthedaddy
PostPosted: 23:02 - 26 Nov 2007    Post subject: Non standard bulb in a standard bike? Reply with quote
I finally managed to get the blown bulb from the headlamp went to Halfords and purchased a H4 bulb as a replacement. With the old one in hand and a new one to compare I could tell that the securing lugs were not in the same place but bought it for a test fit.
It didn't fit.
Tried a bike shop today and when I said that it was a 45/45w bulb he stared at me as if I was mad and asked if I was sure. He asked if it had a 'H' number and it doesn't and bar going to the bike and ripping it out I looked like a n00b.
As far as I know the 7R is not an import, but was a Cat C at one stage and maybe, just maybe had a new front end from an imported bike is my only thought?
Would there be any other reasons why a Jap bike would have a strange non stock part like this?
Finglonga
PostPosted: 23:15 - 26 Nov 2007    Post subject: Reply with quote
H4 bulbs are H4 bulbs, its a standard fitting and there are no variations. So the one you took out sounds like it isn't a H4 bulb. You need to find the type of bulb before spending more money.
Andy Sez....
F.Y.Y.F.F.
Whosthedaddy
PostPosted: 23:21 - 26 Nov 2007    Post subject: Reply with quote
I must give the bloke in the shop kudos as he rang a nearby shop and asked if they would have something as they stock all 'H' range bulbs. It was late and I was in the middle of something so will have to wait till Wednesday with the bulb in hand.
It just seems strange that its causing problems.
The other comments are that its ok for only one light to come on on dipped and both on for full beam, fair play, but one of the filaments is broken and is a pre 2000 bike.
PostPosted: 23:31 - 26 Nov 2007    Post subject: Reply with quote
There are 2 types of H4 bulb it seems:-
https://wwww.vehicle-wiring-products.co.uk/VWPweb2000/lights-3/lights-3.html#gen367
But if it isn't one of them then hopefully that place can help anyway.
PostPosted: 23:35 - 26 Nov 2007    Post subject: Reply with quote
Hmm, sounds familiar:-
https://www.visordown.com/forums/showthread.php?t=248807
Finglonga
PostPosted: 23:37 - 26 Nov 2007    Post subject: Reply with quote
First time I have ever come across that! I stand corrected.
Andy Sez....
F.Y.Y.F.F.
Phil_P
PostPosted: 23:38 - 26 Nov 2007    Post subject: Reply with quote
Prior to halogen bulbs becoming the norm, and H4 bulbs being almost standard for dip/main combinations, the usual was a non-halogen with a circular base with a couple of small cut outs. It sounds like that may be what you have, as they carried on using them in lower power applications like smaller bikes.
It is not enough to win, others must fail.
Moto Guzzi 1100 Sport Injection '96
PostPosted: 23:39 - 26 Nov 2007    Post subject: Reply with quote
Think the P43t and the P45t are the relevant bits for the fittings.
Whosthedaddy
PostPosted: 23:43 - 26 Nov 2007    Post subject: Reply with quote
Spot on, weird problem for a mainstream production bike though?
Here comes the n00b question:
Whats the 45/45 mean anyways. I would have thought it means the difference between dipped and full beam but the wattage is the same?
PostPosted: 23:47 - 26 Nov 2007    Post subject: Reply with quote
Position of the filament determines whether it is dip or main beam. Be entirely possible to have a higher wattage main beam than dip beam.
Phil_P
PostPosted: 00:00 - 27 Nov 2007    Post subject: Reply with quote
If you look at a bulb, you'll see that one of the filaments has a little metal screen below it. That's the dip filament. The one without the screen is the main. They can both be the same wattage, it's where the beam is directed that matters.
samomighty
PostPosted: 01:19 - 27 Nov 2007    Post subject: Reply with quote
My import cbr400 take's "japanese" h4's as there known slightly different position but people have dremeled the holder to fit "UK" h4's i think david silver does the import bulbs for about £5- £6 but that was a few years back. edit* i just looked and on david silver there £5.50 each if they are the same as my 400 Smile
alains
PostPosted: 10:37 - 27 Nov 2007    Post subject: Reply with quote
look here , you will see all bulbs and socket type
https://www.geneva-racing.com/~alains/TUNGSRAM.pdf
Whosthedaddy
PostPosted: 18:06 - 29 Nov 2007    Post subject: Reply with quote
Well I popped into an Aladins cave of a shop and although the microfiche suggests the UK spec bike has a 45/45w bulb it seems that they are as common as rocking horse droppings. So, I walked out of the shop with some H4 bulbs (again), this time the securing lugs had been chopped off with some pliers by the very helpful bloke behind the counter and job done. Thumbs Up
The last post was made 18 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 87.14 Kb
