How can I undo a honda castle bolt without a castle socket?
M1ke
Ped Boi
PostPosted: 23:02 - 26 Nov 2007    Post subject: How can I undo a honda castle bolt without a castle socket? Reply with quote
The subject says it all really. You know the gay castle bolts that honda typically use to hold their engine in the frame? Is there a way to get them undone without spending a small fortune buying a socket off honda? I am not bothered about keeping the bolt, I just want the engine out.
I have found a crap picture of one on google that may give you an idea of what i'm on about.
https://cbrworld.net/photos/modifications/images/183818/500x375.aspx
PostPosted: 23:04 - 26 Nov 2007    Post subject: Reply with quote
Get a normal socket of a suitable diameter and cut notches in it to suit the castellations.
Or do what I do and use a hammer and drift Smile
M1ke
Ped Boi
PostPosted: 23:06 - 26 Nov 2007    Post subject: Reply with quote
What is the success rate for the hammer and drift?
PostPosted: 23:12 - 26 Nov 2007    Post subject: Reply with quote
100% for me - if it don't go 1st time I find a bigger hammer Smile
Sparks!
Sir Tart-a-lot
PostPosted: 23:14 - 26 Nov 2007    Post subject: Reply with quote
You don't need to undo it to take the engine out.
It should be a 13mm HEX (allen) key socket to undo it and a normal socket on the other side then it will pull out easily.
I swapped a 600 F Sport engine a few weeks back and definetely did not undo any castle nuts.
Hope it helps.
Itchy
PostPosted: 23:15 - 26 Nov 2007    Post subject: Reply with quote
Hope it helps.
ta muchly Karma Thumbs Up Very Happy
Itchy
PostPosted: 23:16 - 26 Nov 2007    Post subject: Reply with quote
this then poses the question,
why do Honda use them what do they bolt onto then? Confused
PostPosted: 23:20 - 26 Nov 2007    Post subject: Reply with quote
Often for a top hat shaped nut that goes into a threaded hole to adjust the clearance (or a lock nut on such a nut / bolt). Reduces the amount of clearance required.
Sparks!
Sir Tart-a-lot
PostPosted: 23:21 - 26 Nov 2007    Post subject: Reply with quote
I know the answer to that, just can't remember it!! Laughing it's in the Haynes manual, I remember reading about it... something to do with bolt tension or something?? cant remember now!! Very Happy
PostPosted: 23:36 - 26 Nov 2007    Post subject: Reply with quote
So what's their excuse for using them to hold C90 clutch baskets on with then?
M1ke
Ped Boi
PostPosted: 23:37 - 26 Nov 2007    Post subject: Reply with quote
Thanks for the replies, I shall have a poke at it tomorrow.
c_dug
PostPosted: 23:43 - 26 Nov 2007    Post subject: Reply with quote
The bikes i work on at college use them on the clutch as well (GZ125's) and a few of the big bikes, i think you can tighten up a castlated nut more than a normal nut without the risk of rounding it, or something along those lines anyway...
i can ask the teacher if anybody really wants to know
c_dug
finpos
PostPosted: 00:55 - 27 Nov 2007    Post subject: Reply with quote
I'd check out the price of the tool from Honda, it's not as expensive as you might think, and probably cheaper than buying a socket to cut up to make your own. Guess how I know this.
I think they are used in applications where the nut is recessed into a hole and there's no clearance to get a socket around it.
f.
Sparks!
Sir Tart-a-lot
PostPosted: 00:59 - 27 Nov 2007    Post subject: Reply with quote
The castle nuts on the cbr's (fsport.f4i, fx) for instance... the castle nuts are attatched to the frame and do not need to be taken off to remove anything... so the question was more whats the point in these nuts? that seemingly do nothing.
Jamie S
PostPosted: 01:24 - 27 Nov 2007    Post subject: Reply with quote
And cb750's ,tl125's,cb125's,Tlr200's,TLR250', cg125's,cd125's , Xr125's, Xr200 ,Xr250,XL125's,XL200's,XL250's, sl125's, in fact most Honda's.
I bit the bullet and bought the damn £14 tool, I will pay for it's self in a few years.
https://sdfracing.co.uk/sitebuildercontent/sitebuilderpictures/.pond/castletools.jpg.w180h137.jpg
Mine is the double ended version like the above one, these are the only 2 sizes of castle nut's that Honda have ever used so I won't need to by any more.
Itchy
PostPosted: 09:27 - 27 Nov 2007    Post subject: Reply with quote
Its funny , I managed to get myself a CBR600 workshop manual (I have the PDF version but prefer paper only cost me £4 anyway) , and the whole thing read like a Honda special tool catelogue.
PostPosted: 16:09 - 27 Nov 2007    Post subject: Reply with quote
You want to try getting the headstock bearing races out of a KLE500 or a KLR650. No fewer than six special tools required!
PostPosted: 17:56 - 27 Nov 2007    Post subject: Reply with quote
As Kickstart said they are often used to adjust the clearance between the frame and engine. Many modern bikes use the engine as a stressed-member so it has to be a snug fit in the frame mounts. Since this is a bit impractical by direct-bolting ( due to frame manufacturing tolerances) they use these adjuster-bolts with castle-tops and larger castle-top locknuts to remove any engine-to-frame clearance during assembly. If you can remove and re-fit the engine in a bike with them fitted, they are in need of adjusting beause the gap is too loose.
Gazdaman
I did a trackday!!!
PostPosted: 18:44 - 27 Nov 2007    Post subject: Reply with quote
Yeah, as Geri said.
My SRAD's got one. Got it out with a suitable sized chizel. Used it like a screwdriver Smile
Gaz
The last post was made 18 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 109.31 Kb
