poorly bandit
lynuke
PostPosted: 16:26 - 25 Nov 2007    Post subject: poorly bandit Reply with quote
Hi i am new to this forum so to start off with i would like to say hi to everyone. I'm a aborn again biker and been back on the road for a couple of years riding a 600 bandit. But have very little in the way of mechanical know how. So i am after a bit of advice if anyone can help.
Last week my bike failed to start, it would turn over but not fire. I replaced the battery as the old one would not hold charge. I took tank off checked the filter in tank for gunk (it was fine). Checked tap operation and all fuel lines for blockages etc (fine). I have now replaced the plugs and the bike will start, but only on 2 cylinders 1 + 2. I am getting a spark on 3 + 4 but not firing. I thought maybe a coil gone but if so would that not cause maybe cylinders 1 + 3 not to fire as 3 + 4 on are on seperate coils? As far as i can tell all electrics work fine.
If antone got any ideas i would appreciate it. Thanks
Richard_Schmid
PostPosted: 16:52 - 25 Nov 2007    Post subject: Reply with quote
Possibly a problem with the carberetta - Experts, what do you think?
greatmoorred
PostPosted: 18:46 - 25 Nov 2007    Post subject: Reply with quote
Hi.
My 400 Bandit does something very similar when its low on juice !!
It doesnt like being on reserve and will often run on 3 when it gets that low.
Always best to start at the really easy options and work up. Very Happy
Also these connections pictured (orange and yellow ) were loose on mine, so tightened them up and wd40'd them.
Phil_P
PostPosted: 21:43 - 26 Nov 2007    Post subject: Reply with quote
Make sure that choke linkages are both opening and closing (fully) the choke flaps on all four cylinders.
It is not enough to win, others must fail.
Moto Guzzi 1100 Sport Injection '96
PostPosted: 22:43 - 26 Nov 2007    Post subject: Reply with quote
Are you sure it's turning over?
Could just be your starter motor spinning but the solenoid not engaging.
Have you tried bump starting?
Mark
Ichy
PostPosted: 22:56 - 26 Nov 2007    Post subject: Re: poorly bandit Reply with quote
Think that answers that.
My GSX used to do the same if it wasn't run for a bit. Just left it running on two and the others kicked in eventually.
Make sure the plugs are clean, try heating them up with a blow torch and see if it makes a difference. Are the plugs wet if you take them out when it won't start?
PostPosted: 23:37 - 26 Nov 2007    Post subject: Re: poorly bandit Reply with quote
I should read propally next time Embarassed
lynuke
PostPosted: 11:56 - 27 Nov 2007    Post subject: Reply with quote
Thanks for the tips and pointers guys. I ain't gonna get a chance to look at my bike for the next couple of days, but i will let you know the out come of my tinkerings
cheers
400bandit
PostPosted: 13:00 - 27 Nov 2007    Post subject: Reply with quote
As has already been said, sounds like fuel starvation. I would wip the carbs off and give them a clean. BTW what colour were the old spark plugs you took out? I take it you are running with the standard ar box and not pod filters?
All the best, Joe
Keir
PostPosted: 13:20 - 27 Nov 2007    Post subject: Reply with quote
as others have said. i think its a fuel starvation issue.
If your getting a spark, and the air filters ok then the only other thing needed is fuel. You say you have checked the fuel tap and line so it must be further down the line. Id suspect the carbs too.
either clean them, pay to have them cleaned or just buy a working set.
Current : '08 Yamaha FZ1s
Ichy
PostPosted: 14:12 - 27 Nov 2007    Post subject: Reply with quote
Guys if you read the original post the OP said that his bike is running on two cylinders.
Now before you start ripping your carbs to bits or buying new ones just open the drain screws and see if any fuel comes through. If it does then it means the bowls are filling up as they should. If not then there could well be a blockage in the fuel supply between carb 2 and 3. Next crank the bike over and check if the plugs are wet. If they are then the carbs are supplying fuel. If you have a compression tester just check the pressure is ok. This rules out a problem in the gasket between the two barrels.
You could swap the plugs over between the working and non working barrels and also the leads from the shared coils. This rules out any ignition problems.
if its still not running at this point then I would strip and clean the carbs.
MaybeGuy
PostPosted: 16:11 - 27 Nov 2007    Post subject: Reply with quote
valve spacings
The last post was made 18 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 74.22 Kb
