Decent headlight bulbs
craigs23
Mr Muscle
PostPosted: 20:01 - 27 Nov 2007    Post subject: Decent headlight bulbs Reply with quote
Can anyone personally recomend one?
I bought some supposed brighter, blue/clear bulbs recently but they're about the same as standard equipment.
Really need something that actually works. There's sections of my commute where I'm only guided by car's tail lights or road markings. Sooner or later there's going to be something in the road which I'm not going to be able to see...
Finglonga
PostPosted: 20:54 - 27 Nov 2007    Post subject: Reply with quote
Only thing that will make a big difference are Gas Discharge lights. The rest are all pretenders.
Another option is auxiliary lighting, maybe a Hella DE fog to add to the dip beam and FF50 for the main beam.
Andy Sez....
F.Y.Y.F.F.
TUG
PostPosted: 21:20 - 27 Nov 2007    Post subject: Reply with quote
how do you fit HID's to a bike?do they just use a similar locking mech to fit where the old lights where? i'm very confused on how to fit a kit, plus i have twin lights so do i need 2 kits? Confused Neutral
Haz ER-5, innit!
craigs23
Mr Muscle
PostPosted: 22:11 - 27 Nov 2007    Post subject: Reply with quote
Is the gas discharge ( Laughing ) a difficult mod?
Finglonga
PostPosted: 23:45 - 27 Nov 2007    Post subject: Reply with quote
Simple, 2x Bulbs(same type as bulbs already fitted), Starter/Ballast box fitted somewhere for each bulb(most new ones are size of a fag packet now). Then just need to wire them up as per the instructions. 1 wire to battery, a wire to earth from ballast and also wires from ballast to bulbs and a couple to turn lights on and off through a relay from your original light circuit. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
craigs23
Mr Muscle
PostPosted: 23:50 - 27 Nov 2007    Post subject: Reply with quote
Cheers Fing. Thumbs Up
Got a link from where you found yours?
chrisgsxr
PostPosted: 00:29 - 28 Nov 2007    Post subject: Reply with quote
The High Intensity Discharge bulbs are unquestionably the best bulbs as the gas light gives your fantastic vision.
As im a tight arse I just use 100W H4s ... very cheap and illegal but fantastically good.But beware I wouldnt be fitting these if my bike had a plastic reflector in the headlamp.Glass 1s should be fine Thumbs Up
PostPosted: 00:32 - 28 Nov 2007    Post subject: Reply with quote
But then so are the aftermarket HID kits.
panrider_uk
PostPosted: 00:33 - 28 Nov 2007    Post subject: Reply with quote
And if your alternator can cope Smile
Mark
Keir
PostPosted: 11:15 - 28 Nov 2007    Post subject: Reply with quote
the best normal bulbs i have found are PIAA ones. they are expensive at £40-£50 a set but they are as good as you are going to get without going HID.
I had HID on my K3, although the light was great the ballasts proved to be diffcult to locate on a bike. i ended up stuffing them in the nose cone of the bike, which luckily was big on the K3 600 - might not be as easy on a naked!
Current : '08 Yamaha FZ1s
Finglonga
PostPosted: 12:08 - 28 Nov 2007    Post subject: Reply with quote
Best shopping around as the prices are always changing, cant get the ones I had anymore. and the ballast boxes are getting smaller and smaller. Most are good quality, the only problem is some whistle when they are on. Shocked
Sold my old ones, there are 50w bulbs out now (35w are the norm) so might invest in some of them. Thinking
Andy Sez....
F.Y.Y.F.F.
MarkJ
PostPosted: 12:15 - 28 Nov 2007    Post subject: Reply with quote
I think there is an ebay seller called diane-shop. Some people off here have bought HID kits from there and say they are reasonable.
tsmith
PostPosted: 17:22 - 28 Nov 2007    Post subject: Reply with quote
Got one of these fitted myself and the difference is amazing. Same wattage as normal, no extra heat and they don't dazzle other road users. Just a simple bulb swap.
https://www.powerbulbs.com/product_detail.asp?prod=111
Osram NightBreaker. 90% more light than normal.
The Tot
PostPosted: 18:49 - 28 Nov 2007    Post subject: Reply with quote
Craig, do a search for my thread on Philips power Xtreme. Similar in performance to the nightbreakers - be very difficult to tell them apart since they're both 80%+ rated. Marked improvement on the performance. Obviously, having a clear and clean reflector and bulb helps matters a great deal. 20 quid off ebay does the trick.
Personally, i wouldn't bother with those H.I.V kits!
Never argue with autism
LeeR
PostPosted: 19:06 - 28 Nov 2007    Post subject: Reply with quote
Halfords Super Brilliance 50% brighter Xenon (448SB) are usually £15 each, but around this time of year they're on a BOGOF. I've had these and the PIAA and to be honest the difference between them is not as noticable as you'd think, but there is a difference over a standard bulb. Thumbs Up
My claim to fame: Austin Vince nicked my pen...
iCraig
PostPosted: 20:49 - 28 Nov 2007    Post subject: Reply with quote
I have a set of Phillips Power Xtremes in my car and the difference between standard bulbs is phenominal, can imagine the same on bike too!
SinceNow
PostPosted: 22:39 - 28 Nov 2007    Post subject: Reply with quote
Would the Phillips Power Xtremes bulbs fit ok in a CG?
Finglonga
PostPosted: 23:12 - 28 Nov 2007    Post subject: Reply with quote
Times that by 10 and you have the Gas Discharge, only thing that even comes close are the PIAA bulbs but they are nearly the same price as an HID kit.
The doubters have obviously never tried HID. Believe me you will never go back.
Andy Sez....
F.Y.Y.F.F.
Keir
PostPosted: 23:17 - 28 Nov 2007    Post subject: Reply with quote
I have!
The light was good but mine buzzed a fair bit and were difficult to locate the ballast well. When the ballast is the size of a matchbox ill try again, 2 years or so should do it.
for all out light i agree HID is the future but at this time on a motorcycle id still go with good normal bulbs.
kawakid
PostPosted: 23:48 - 28 Nov 2007    Post subject: Reply with quote
Think the ones I always use are the Philips BlueVision.
They came top in Ride while ago.
Managed to blow one last year when the rectifier went, not cheap and I think I could only get in packs of 2s. So 1 spare in the garage.
The Z has just the standard Kwak supplied bulbs in it, it never sees dusk, night, rain, so its not as important.
I've a twin and a 4.
LUXY DJ
PostPosted: 15:18 - 29 Nov 2007    Post subject: Reply with quote
HID!!!
went from normal 60/55w H4s - 100/90W H4s - HID 8000K
Arrow normal
https://img.photobucket.com/albums/v232/DJLUX/GSXR/WOT.jpg
Arrow HID
https://img.photobucket.com/albums/v232/DJLUX/GSXR/S7003258.jpg
& even that pic dont do it justice!
even better is once you got HID, you take them to any & every vehicle in future Thumbs Up
GSXR750
TUG
PostPosted: 15:20 - 29 Nov 2007    Post subject: Reply with quote
lol you can see each peice of dust on the lense, bravo! i want HID's!!!
Haz ER-5, innit!
LUXY DJ
PostPosted: 15:30 - 29 Nov 2007    Post subject: Reply with quote
Laughing na thas from where it was raining + where i have my headlight cover stuck on Wink
but they are still ALOT better!, i couldnt even take of a pic of it head on cause they where just to bright & came out on cam as just a big arse bright smear! Mr. Green
i can use my black visor @ night with them with no prob
https://img.photobucket.com/albums/v232/DJLUX/GSXR/S7003267.jpg
GSXR750
craigs23
Mr Muscle
PostPosted: 17:54 - 29 Nov 2007    Post subject: Reply with quote
Interesting.
Anyone got some photos of the Night Breakers as comparison?
I've concluded that riding almost blind at night, when it's raining is near suicidal.
Nb
PostPosted: 19:06 - 29 Nov 2007    Post subject: Reply with quote
Im another HID fan, put a cheap set in my bike and the difference is very impressive. Wont have another bike with normal bulbs and will soon be putting a cheap set of HIDS in my car. Thumbs Up
Normal filament bulbs are just old hat these days, sure you can get 100w bulbs but thats stupid when HIDS consume less power whilst being brighter anyway? Laughing
The last post was made 18 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 129.86 Kb
