How do you top up the battery?
5v3d3b0
PostPosted: 18:34 - 04 Dec 2007    Post subject: How do you top up the battery? Reply with quote
I just did it by opening up all the yellow plastic screws and pouring a little distilled water in each hole...Maybe I messed up?
I'll see if the bike starts now Laughing
Phil_P
PostPosted: 19:00 - 04 Dec 2007    Post subject: Reply with quote
Sounds about right. As long as the fluid is between the min and max marks.
It is not enough to win, others must fail.
Moto Guzzi 1100 Sport Injection '96
5v3d3b0
PostPosted: 23:06 - 04 Dec 2007    Post subject: Reply with quote
The thing is I can't see where the fluid is, but it seemed to be non existent. I shook the battery around before pouring anything in and there was no sound at all...
Ariel Badger
PostPosted: 23:40 - 04 Dec 2007    Post subject: Reply with quote
Take care that you do not knock your tank onto the floor whilst replacing the battery.
Paddy Blake
PostPosted: 23:48 - 04 Dec 2007    Post subject: Reply with quote
Shine a light in the other side when you are checking the level and you
will see it better.
Paddy.
alains
PostPosted: 01:07 - 05 Dec 2007    Post subject: Reply with quote
1cm over the plates , i've learn that 47 years ago at school
st3v3
PostPosted: 01:14 - 05 Dec 2007    Post subject: Reply with quote
Don't forget to give it a good charge too.
Finglonga
PostPosted: 12:42 - 05 Dec 2007    Post subject: Reply with quote
If it was dry the chances are the plates may have buckled with charging and you may find it won't hold its charge.
Andy Sez....
F.Y.Y.F.F.
Phil_P
PostPosted: 15:38 - 05 Dec 2007    Post subject: Reply with quote
A good way of getting the level right on a non see through battery is to use an eye dropper or similar, hold it against the side of the battery so the tip lines up with the 'max' mark. Put a bit of tape round the dropper level with the top of the battery. When you top up the battery, put the dropper through the filling holes up to the tape mark and suck out any excess (or just gradually fill tip the dropper starts to pick up a bit of acid). A syringe and a bit of tube works just as well (even the one you use for bleeding your brakes) Very Happy
PostPosted: 16:38 - 05 Dec 2007    Post subject: Reply with quote
If it was empty I would say it's knackered. When I bought my scooter my battery it was really low on water, topped it up and charged it but it couldn't hold charge. Bought a new battery for £15.
Mark
The last post was made 18 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 62.96 Kb
