RS 125 WONT START!/HELP? PT2
stirlinggaz
PostPosted: 22:04 - 06 Dec 2007    Post subject: RS 125 WONT START!/HELP? PT2 Reply with quote
Hi all,
after all the problems i had with 34mm carb, i gave up & put standard carb back on.
bike started 1st time!
so i guess batterys ok! (see previous posts)
bike ran idling for a while,
while i tightened up everything.
nipped indoors for helmet so i could go for a test run,
& when i came back out, it had conked out!
checked carb bowl, full of petrol, but floats look ok.
epmtied it, cleaned it & put carb back on.
now wont start,
coughs now & again but nothing else.
any ideas?
checked obvious,
kill switch,
battery,
petrol in tank.
so what next?
any advice/suggestions welcome,
cheers,
GAZ
5v3d3b0
PostPosted: 22:24 - 06 Dec 2007    Post subject: Reply with quote
Fuel tap?
Fuel line?
Ben.
PostPosted: 22:58 - 06 Dec 2007    Post subject: Reply with quote
check no hoses are blocked kinked, and in the carb check for any dirt
follow my racing season
Race bike - R6
Road bike - sv650
stirlinggaz
PostPosted: 15:36 - 07 Dec 2007    Post subject: Reply with quote
hi,
carbs been stripped & cleaned.
fuel line is ok- petrol comes out when it is disconnected from carb.
any other ideas?
cheers,
GAZ
19van71
PostPosted: 19:58 - 07 Dec 2007    Post subject: Reply with quote
If your spark plug is wet then this indicates that fuel is not necessarily the problem. Try a new spark plug (correctly gapped) and see if 1. there is a spark. 2. if it will run.
Good luck Very Happy
stirlinggaz
PostPosted: 23:42 - 07 Dec 2007    Post subject: Reply with quote
Hi,
tried another spark plug (exact same type)
getting spark cos i checked it against frame.
but bike still wont start!
ready for giving up & either throwing it in river across road or stripping it down & selling parts!
anyone else help/advise?
cheers,
GAZ
stirlinggaz
PostPosted: 18:41 - 09 Dec 2007    Post subject: Reply with quote
hi,
tried a new spark plug.
the one i removed was wet?
anyway, definately getting a spark! (tested against frame)
but bike still wont start,
coughs as if about to start, but then nothing.
when i tip the carb, petrol pours out,
so fuel going into carb ok.
that rules out fuel line.
any more ideas?
cheers,
GAZ
The last post was made 18 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 52.29 Kb
