Car problem......not starting. (not my car for once)
iCraig
PostPosted: 20:34 - 07 Dec 2007    Post subject: Car problem......not starting. (not my car for once) Reply with quote
Its not my car for once but my dads Nissan Micra which is very reliable usually.
The problem with the car is its just not starting, seems like theres not enough go in the battery. It was last driven last night, but in the deluge of rain it was driven through about a foot of water, which was unavoidable due to it being dark and unlit and not seeing it till we were in it.
Anyway we get through the water and it ran fine, and even started fine to be able to put it away for the night in the garage.
All the belts are intact etc.
I've even tried to jump start it from my car, but to no avail.
The car does turn over however and there is no water in the oil.
Any ideas what it could be?
Nb
PostPosted: 22:14 - 07 Dec 2007    Post subject: Reply with quote
What year is the micra?
iCraig
PostPosted: 22:25 - 07 Dec 2007    Post subject: Reply with quote
Its a 1998 model.
Nb
PostPosted: 22:32 - 07 Dec 2007    Post subject: Reply with quote
Craig- wrote:
Its a 1998 model.
So its a k11 then, the most likely cause is that you have gotten your distributor soaked.
If you know how to, take it off and see if its damp inside. And if it is, dry it as best as possible or you can use wd40 aswell.
strag
PostPosted: 01:22 - 08 Dec 2007    Post subject: Reply with quote
Its a Micra, throw it away and buy another one.
carbon bling
iCraig
PostPosted: 09:55 - 08 Dec 2007    Post subject: Reply with quote
Mmm, yeah throw it away. Great suggestion considering its not my car and my dad loves the thing.
iCraig
PostPosted: 09:58 - 08 Dec 2007    Post subject: Reply with quote
Nb, cheers for the assistance so far, but I've had the dizzy off and its dry as a bone. All the engine seems totally dry.
Anything else it could be? The car just seems like it has a flat battery and doesn't have enough power, even with another car trying to jumpstart it.
sagiliam
PostPosted: 10:20 - 08 Dec 2007    Post subject: Reply with quote
Battery might be shot...you could try putting a battery in from another car, and if still doesnt go then you know the battery is ok?
Did you try wd40 on your dizzy cap? Try the simple stuff first before you start moving onto things like the starter motor etc.
HTH
Cigaro
PostPosted: 10:28 - 08 Dec 2007    Post subject: Reply with quote
It may be flooded. K11 Micra's have a habit of doing this.
Try this: remove the fuel pump fuse from the fusebox. Turn the engine over for 5-10 seconds. It should start, if it does, let it run till it stalls, and put the fuse back in.
I noticed that you said you started it up just to put it away in the garage, which is normally the precursor when this happens.
Hope that helps.
Nb
PostPosted: 13:55 - 08 Dec 2007    Post subject: Reply with quote
Hope that helps.
Like he says it could be flooded, try holding the accelerator to the floor whilst cranking it.
Cigaro
PostPosted: 18:02 - 08 Dec 2007    Post subject: Reply with quote
On Micra's over a certain age the fuel injection system doesn't have a 'flood clear' mode so you have no choice but to do the fuse trick.
Not saying that is the case for the year you have though, it worked on my mum's 2000 model Micra.
Finglonga
PostPosted: 22:39 - 08 Dec 2007    Post subject: Reply with quote
As above, the other halfs Micra does it all the time. There is a knack to starting them if you have flooded them. No stripdown is needed. Wink
Andy Sez....
F.Y.Y.F.F.
iCraig
PostPosted: 23:47 - 08 Dec 2007    Post subject: Reply with quote
All sorted now guys, cheers for the help. Turns out the battery was just past it.
With it being 9 years old I don't think its done too bad!
sagiliam
PostPosted: 16:24 - 09 Dec 2007    Post subject: Reply with quote
i suggested that. i think i shud get karma cookies Very Happy
The last post was made 18 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 79.18 Kb
