honda ch125 clutch doesent work!!!HELP!!
Bike Chat Forums Index -> General Bike Chat Goto page 1, 2, 3, 4, 5  Next
custom-biker
PostPosted: 23:29 - 08 Dec 2007    Post subject: honda ch125 clutch doesent work!!!HELP!! Reply with quote
hello,
i have been working on a 1/2 sized race bike which has a cg125 engine in it which i nstalled myself.
i got round to putting all the chain parts on today and i realised that whn its in gear and when i pull the clutch in it doesent roll and now that i have selected a gear it wont come back out of selection that gear!
i got this engine off ebay 8 months ago and havent started it but was planning to tommorw untill i came across this problem!
my question is what is wrong with it and waht do i need to do?
any 1 have any pics?
thanks.
any help is verrrry much apriciated
is you can turn you aint goin fast enough.
Jamie S
PostPosted: 23:36 - 08 Dec 2007    Post subject: Reply with quote
Your clutch plates will be stuck together , time to strip them down I'm afraid.
Make sure you re new the gasket as well , and also clean up both surfaces prior to re fitting.
lukamon
PostPosted: 00:11 - 09 Dec 2007    Post subject: Reply with quote
clutch in, 1st gear, jump (literally, if possible) on kickstart. Thumbs Up
killa wrote: Im an ass man myself
Jamie S
PostPosted: 00:14 - 09 Dec 2007    Post subject: Reply with quote
lukamon wrote:
clutch in, 1st gear, jump (literally, if possible) on kickstart.....
Foot slips off the kickstart , the kickstart then goes up your trouser leg , you and the bike then proceed to fall over in a heap on the floor...... Wink
lukamon
PostPosted: 00:20 - 09 Dec 2007    Post subject: Reply with quote
or, run with engine in gear till it starts, then pull clutch in and open the throttle Smile did this on my kmx and it loosened up almost straitaway works fine now
lukamon
PostPosted: 00:21 - 09 Dec 2007    Post subject: Reply with quote
on the other hand it is a cg125 engine which couldnt pull a greased stick out of a pigs arse......... so that might not work either
Sad
Ariel Badger
PostPosted: 00:34 - 09 Dec 2007    Post subject: Reply with quote
Start it with the front wheel against a wall and drop her into gear with the clutch in.
custom-biker
PostPosted: 13:32 - 09 Dec 2007    Post subject: Reply with quote
im afraid because the engine is sooooo oversized for the bike it doesenty have a kick start because the exhaust is in the way.
its bump start only!!!!
what should i do?
do i still have to strip down?
i dont have any money to spend on it so can i still use the same pads?
can some 1 run me through what to do please?
would be a GREAT help!
cheers Thumbs Up
Ariel Badger
PostPosted: 13:40 - 09 Dec 2007    Post subject: Reply with quote
Striping a clutch should not take long.
custom-biker
PostPosted: 13:54 - 09 Dec 2007    Post subject: Reply with quote
can i ke4ep all the stuff inside?
custom-biker
PostPosted: 14:59 - 09 Dec 2007    Post subject: Reply with quote
right...
ive taken the over off and it loks as tho some 1s had a go before (from bured screws)but everything seems to be on good condition!
is the pin that juns through the crank shaft when you push it on ment to me because thats what the clutch lever on the casing lines up to but it dont seem to move?
what else do i do?
Jamie S
PostPosted: 15:47 - 09 Dec 2007    Post subject: Reply with quote
Ok so you have the cover off , right ?
Next you get a flat bladed screwdriver between each plate and loosen them off (pry them apart a bit), simple as that.
Removeing all the plates from a Cg clutch requires a special tool which cost £15 , but just doing the screwdriver trick should sort them out.
custom-biker
PostPosted: 16:04 - 09 Dec 2007    Post subject: Reply with quote
yes the cover is right off?
can you get a pic off google and lable what plates to lift off?
im realy confused!
custom-biker
PostPosted: 16:07 - 09 Dec 2007    Post subject: Reply with quote
i think this is it?
but its allready apart?
saya88
PostPosted: 16:09 - 09 Dec 2007    Post subject: u have to re do it Reply with quote
u have to open it and then do it from the beginning i mean re do it they r stuck together or try to puch it and start it and then take the gear out with out using clutch does work on a bad clutch
Life is a game u get only one chance to play (Honda CG125,Honda CD200,Kawasaki KE175,Kawsaki GTO125 and now Kawasaki ZX6 R current suzuki GSX-R 750)
custom-biker
PostPosted: 16:10 - 09 Dec 2007    Post subject: Re: wat shall i buy Reply with quote
saya88 wrote:
shall i buy kawasaki zx10 r 04 or suzuki gsxr 1000 04 plz help
wrong thread mate Thumbs Up
custom-biker
PostPosted: 16:19 - 09 Dec 2007    Post subject: Re: wat shall i buy Reply with quote
this are the actul pics of my engine please could you lable them on paint or sommin?
custom-biker
PostPosted: 16:20 - 09 Dec 2007    Post subject: Re: wat shall i buy Reply with quote
pic 2
custom-biker
PostPosted: 16:21 - 09 Dec 2007    Post subject: Re: wat shall i buy Reply with quote
pic 3
Jamie S
PostPosted: 16:33 - 09 Dec 2007    Post subject: Reply with quote
You need to get your flat bladed screwdriver and prise apart the plates, See were the red line is , there.
custom-biker
PostPosted: 16:47 - 09 Dec 2007    Post subject: Reply with quote
so i just put a flat bedded screw driver in beween the and it will work?
is there ment to be a 1mm gap or sommin?
cheers mate Thumbs Up
Jamie S
PostPosted: 16:50 - 09 Dec 2007    Post subject: Reply with quote
All the plates should be free to move on there own , you will find that they will all be stuck as "one" becuase of standing over time , And also having no oil between them.
custom-biker
PostPosted: 16:53 - 09 Dec 2007    Post subject: Reply with quote
hi mate,
so does each plate count fr each inderviaual gear?
and sould they all spin seporatly?
cheers mate
lukamon
PostPosted: 17:15 - 09 Dec 2007    Post subject: Reply with quote
no, the matal plates and the cork plaes should all spin as one when the clutch is engaged and either cork only orr metaL ONLY WHICH CLUTCH IS OPEN. Thumbs Up
custom-biker
PostPosted: 17:16 - 09 Dec 2007    Post subject: Reply with quote
i i stuck a screwdriver in betwnn(opening up about 1/2 cm) then and put the case back on and pulled the clutch in fully and it STILL donesent roll in gear?
and i tried julting it along with clutch FULLY in but nothing?
bearing in mind there is no oil in it should i spray some WD40 in there?
The last post was made 18 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 123.92 Kb
