TZR125...wont start :(
element
PostPosted: 22:44 - 11 Dec 2007    Post subject: TZR125...wont start :( Reply with quote
Hadnt started it for well over a month so I kicked it over the other day and it was running fine till I killed the engine then tried to start it again. I have a good spark and the plug is getting fuel..
any ideas?
I did manage to get it started again briefly but it just cut out (like it ran out of fuel) and it hasnt been able to start since..
thanks in advance Smile
edit... wont bump start either.... Sad
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
PostPosted: 23:32 - 11 Dec 2007    Post subject: Reply with quote
How long had you had it running for?
panpan
Could possibly be the fuel. Fuel has a shelf life of about 2 weeks. After this period, it becomes less combustive and therefore does not ignite as easily. Perhaps try some new fuel
st3v3
PostPosted: 23:42 - 11 Dec 2007    Post subject: Reply with quote
My bikes been stood for about 2 month now, with half a tank of petrol but about 3 weeks ago I took it about 4 miles (there and back) to the MOT place and it was fine.
Tried replacing the plug?
deanoet
PostPosted: 23:44 - 11 Dec 2007    Post subject: Reply with quote
Didnt flood it did you?
With it being colder it will be harder to start it and keep it running, had to hold my bike on full choke for a few minutes before it would idle with middle choke
panpan
PostPosted: 23:48 - 11 Dec 2007    Post subject: Reply with quote
I miss the summer days where you could just give the starter a tap and the bike fires up perfectly with no need for any choke Cool Sad
Finglonga
PostPosted: 13:34 - 12 Dec 2007    Post subject: Reply with quote
Rubbish! My bike has been off the road for over a year and it still starts first time every time. Fuel has that many additives it wont go off unless you leave it open to the air for an extended period.
The car before now has had fuel in it for months as it was rarely used and also never had any trouble starting.
Andy Sez....
F.Y.Y.F.F.
Finglonga
PostPosted: 17:37 - 12 Dec 2007    Post subject: Reply with quote
That could explain why its so bleeding expensive. Wink
Andy Sez....
F.Y.Y.F.F.
st3v3
PostPosted: 19:06 - 12 Dec 2007    Post subject: Reply with quote
Or top it up with the new stuff and risk it buggering vehicles, hence the price being so high for fear of vehicle repair bills. Laughing
How is the bike, any progress?
panpan
PostPosted: 19:39 - 12 Dec 2007    Post subject: Reply with quote
Vincent wrote:
Aye, if it only lasted 2 weeks, the petrol stations would have to empty their tanks every fourtnight and throw what's left away.
They refill their tanks like every week or something
element
PostPosted: 21:38 - 12 Dec 2007    Post subject: Reply with quote
tried fresh fuel and no luck. havent tried a new plug but Im sure the plug thats in the engine right now is fine since the bike started 5 minutes before I tried to kick it over again! I did clean the plug just to be sure..
I dont think its flooding either as Ive tried to kick it over on 4 seperate occasions now and no luck Sad Just dont understand how it would start then 5 minutes later it wouldnt Confused
completely baffled Sad
Pie-Roe
PostPosted: 22:20 - 12 Dec 2007    Post subject: Reply with quote
Fuel tap is 'on' yeah? If not, you may have just used the remaining fuel in the carbs and fuel line, and then run out...
Pyro
element
PostPosted: 19:11 - 13 Dec 2007    Post subject: Reply with quote
yeyh fuel tap is on.. fuel is gettin to the plug so there isnt a fuelling problem...
panpan
PostPosted: 19:45 - 13 Dec 2007    Post subject: Reply with quote
Only remaining problems could be compression or timing then. Either not enough compression in the case, or the plug timing is off. Stick your thumb over the plug hole (with the plug out) and thumb the starter. The compression should be able to push your thumb off the hole.
element
PostPosted: 21:45 - 13 Dec 2007    Post subject: Reply with quote
Its kickstart only (bike is a registered 92' but i think it may be as old as an 89') anyhow ive tried that and there is compression. dont think the timing is adjustable on a tzr either (CDI controls it I thought).
A white spark is a good spark right? Or is a blue spark better.. Can never remember..
panpan
PostPosted: 23:36 - 13 Dec 2007    Post subject: Reply with quote
Look for a blue spark
element
PostPosted: 13:00 - 16 Dec 2007    Post subject: Reply with quote
Cool. I'll try a new spark plug and see if that makes a difference.
element
PostPosted: 18:27 - 27 Dec 2007    Post subject: Reply with quote
new plug, blue spark and started first time Thumbs Up
cheers Smile
panpan
PostPosted: 22:35 - 28 Dec 2007    Post subject: Reply with quote
Good job. Anyway, were you getting a white spark then? Was it strong?
st3v3
PostPosted: 23:44 - 28 Dec 2007    Post subject: Reply with quote
Sorry, just as a footnote:
The timing on something that old is probably controlled by a wedge of metal stuck securely into the shaft for the alternator.
In a roundabout way.(I think that's right)
The last post was made 18 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.68 - MySQL Queries: 13 - Page Size: 117.36 Kb
