Removing a Datatool Duo immobiliser
Wave2k
G's Stalker
PostPosted: 22:02 - 10 Dec 2007    Post subject: Removing a Datatool Duo immobiliser Reply with quote
I want to remove this immobilser, its a very dangerous little item this and nearly cause a fairly bad accident on track when it decided to cut in.
Is this easily done ?
a little info on it
https://www.datatool.co.uk/consumer/products/products/index.php?product=duo
Ducati 1299 Panigale
2009 Corvette C6 z51
tatters
Exxon Valdez
PostPosted: 22:41 - 10 Dec 2007    Post subject: Reply with quote
get hold of a wiring diagram for your bike and trace back the wires from the unit all there will be is cable providing a 12v when the ingention is on and a permanent 12v supply to the unit plus 4 cables for two immobilization circuits (supply to HT coils/starter motor normally) these would have to linked out as the immobilizer basically acts as a switch to prevent these from working.
should be quite straight forward.
PostPosted: 21:18 - 11 Dec 2007    Post subject: Reply with quote
Just leave it parked on the street. Some wee scrote will steal the bike, bypass the immobaliser for you then dump it somewhere a few days later.
As I pointed out to the police when my MZ was stolen, if he managed to bypass a 12 lead immobaliser, why the hell is he stealing bikes? He could make a fortune as an auto electrician (most of the ones I know wouldn't be able to do that job down a back-alley armed with a pair of pliers and a penknife).
Gazdaman
I did a trackday!!!
PostPosted: 14:21 - 12 Dec 2007    Post subject: Reply with quote
You got PM, not really gonna post it on a public forum.
Gaz
the grim reaper
PostPosted: 14:23 - 12 Dec 2007    Post subject: Reply with quote
I've removed more alarms than I care to remember and, nine times out of ten, they are so badly fitted that it's easier than it should be. At the end of the day, even if the fitter has done a perfect job, it's purely a case or tracing the wires from the immobiliser to the loom and removing the splices where required.
Alternatively, take a trip to sunny Southampton and I'll do it for you, for a botttle of JD Mr. Green
Before you wonder, I'm a trained bike mechanic and also an electronic engineer, comes in handy when an alarm decides to catch fire, as the one on my old Thundercat did Shocked
Grim
calum17
PostPosted: 14:31 - 12 Dec 2007    Post subject: Reply with quote
if you get it removed - would you sell it?
im interested if you are Smile
PostPosted: 15:21 - 12 Dec 2007    Post subject: Reply with quote
Surely if they've done a proper job, each wire should have been removed altogether and a black one running through the immobaliser put in its place.
My one replaced half the loom. All the ignition switch did was power up the immobaliser, there were no other wires going to/from it. All the wires coming from the CDI unit were black too and fed into the immobaliser box.
Some wee bastard still managed to get it going though. I was quietly impressed about that. He must have REALLY wanted it because the bypass would have taken me a couple of hours with a wiring diagram in front of me.
Wave2k
G's Stalker
PostPosted: 16:00 - 12 Dec 2007    Post subject: Reply with quote
Not sure if i would sell it, make me an offer Wink
calum17
PostPosted: 16:41 - 12 Dec 2007    Post subject: Reply with quote
i dont know what it is worth - if you do decide PM me. i'll be interested - even in a month or two cos i wont have a full alarm system by then so an imoboliser would make me feel better.
the grim reaper
PostPosted: 21:29 - 12 Dec 2007    Post subject: Reply with quote
You find me an alarm fitter who actually does that and I will be well impressed. If you know of one then shake his hand for me and congratulate him on doing a good job.
Grim
PostPosted: 23:17 - 12 Dec 2007    Post subject: Reply with quote
You want a job done properly, do it yourself.
the grim reaper
PostPosted: 14:19 - 13 Dec 2007    Post subject: Reply with quote
Yep, that's what I thought Mr. Green
Grim
There is a gap of 243 days between these two posts...
gilburton
PostPosted: 10:30 - 13 Aug 2008    Post subject: Reply with quote
I've just had a problem with my duo immobiliser.It hasn't worked for some time but the bike started and ran ok.I was coming home from work on the A14 dual cariageway when the bike cut out on the outside lane whilst overtaking(well it would wouldn't it?) I was only a couple of miles from home but I'm not pushing a dragstar on a busy dual carriageway with no hard shoulder.RAC to the rescue,and quite quick as well! The upshot is that I had all electrics except ignition/starter so I started checking the usual suspects eg side stand switch/kill switch etc. but all checked out ok.This left the duo immobiliser so I bit the bullet and started tracing the wiring.Believe me this one was fitted properly.I gradually cut open the loom and disconnected any sensor wires and it came down to 3 wires left.I had to cut the loom back to the headstock to find the ends.(this alarm fitter certainly earned his money)I found that the wire from the ignition switch to the ecu/icu had been replaced by a black wire so all that had to be done was find the black wire to the ecu and join it directly to the ignition switch leaving out the immobiliser and the other wire was just an earth.During the wire search I found that a couple of the duo wires had chafed through which is probably why the immobiler stopped working in the first place then stopped the bike??? Took about 3 hours but it was worth it Laughing
The last post was made 18 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.9 - MySQL Queries: 13 - Page Size: 82.97 Kb
