Lights not working??
mattjs895
PostPosted: 18:24 - 12 Dec 2007    Post subject: Lights not working?? Reply with quote
ok well my main headlights are not working, i have tested the wires with a voltometer and its showing up 12v for both high and low beam.
with this in mind, the headlights should work but as soon as they are connected, the lights do not work and there seems to be no power getting to them.
my dad reakons that it has something to do with the load going through the wire, or even the high low beam switch..
if it is one of these, what ways are there to test which one it is, or is there any other ideas for this reason.
cheers
matt
iooi
PostPosted: 18:35 - 12 Dec 2007    Post subject: Reply with quote
Bulb Ok ????
Is that power to the back of the connector for the bulb, or at the switch.
mattjs895
PostPosted: 18:37 - 12 Dec 2007    Post subject: Reply with quote
yea the bulb is ok and the power is to the connector at the back of the bulb..
UnknownStuntm...
PostPosted: 18:41 - 12 Dec 2007    Post subject: Reply with quote
If the bulb works, and there's power there, it suggests there isn't a good earth....
mattjs895
PostPosted: 18:42 - 12 Dec 2007    Post subject: Reply with quote
i have tried connecting the power to the bulb, and then touching the bulb onto the frame and this is not working either..
ZaphodBeeble
PostPosted: 18:46 - 12 Dec 2007    Post subject: Reply with quote
How do you know the bulb is OK? Are you just looking at the filament? Get a new bulb, it will take that out of the equation. If you have power and a good earth then it HAS to be the bulb, no question about it.
Z
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
mattjs895
PostPosted: 18:48 - 12 Dec 2007    Post subject: Reply with quote
i have 4 good bulbs and each of them have been tested...
iooi
That would tend to say the bulb is knackered..
What type of bulb is it ?
I take it you are putting power to the prongs at the back and the metal ring to a suitable piece of bare metal frame.
Personally i would try to live and earth on battery.
mattjs895
PostPosted: 18:50 - 12 Dec 2007    Post subject: Reply with quote
how would i do that?
ZaphodBeeble
PostPosted: 18:51 - 12 Dec 2007    Post subject: Reply with quote
Get a couple of wires and connect them to the battery terminals then touch them on the terminals of the bulb just briefly. It should flash. Z
mattjs895
PostPosted: 18:55 - 12 Dec 2007    Post subject: Reply with quote
have just tried that a the bulbs are working
ZaphodBeeble
PostPosted: 18:59 - 12 Dec 2007    Post subject: Reply with quote
It must be a problem with the connector that fits onto the bulb then. Are you testing the front or back of the connector? Find out which connector is the positive terminal and test for voltage. Then change the multimeter to Resistance and put one of the meter terminals in the neutral connector and one meter terminal onto the frame. The resistance should be very low or 0 ohms. That will show that you have a good supply and good earth.
Z
mattjs895
PostPosted: 19:08 - 12 Dec 2007    Post subject: Reply with quote
i'm testing the front clips which would connect with the light bulb..
and there is still voltage going through, and no resistance..
ZaphodBeeble
PostPosted: 19:23 - 12 Dec 2007    Post subject: Reply with quote
When you test for voltage are you putting the positive meter probe into the connector and the negative probe to the chassis?
mattjs895
PostPosted: 19:26 - 12 Dec 2007    Post subject: Reply with quote
i am testing it by putting one rod on the low or high beam connector and the other on the live on the connector...
ZaphodBeeble
PostPosted: 19:35 - 12 Dec 2007    Post subject: Reply with quote
Try it by putting the negative test probe on the chassis. Then try all the connectors with the positive probe and see what voltages you get for each.
mattjs895
PostPosted: 19:54 - 12 Dec 2007    Post subject: Reply with quote
i was only getting about 7 volts from the low beam connector and nothing from the high beam...
any suggestions
ratboy
PostPosted: 20:50 - 12 Dec 2007    Post subject: Reply with quote
check the treminals for dirt debris and any oxide. clean them with some wd40 style stuff and a toothbrush. check the continuity from each battery terminal to the light. check and grease any connectors (scrub them if dirty or oxidised). if that doesnt work test the switch for continuity and power. if all of the circuits are continuous, terminals and connectors are clean and switch is working its the bulb or battery.
ZaphodBeeble
PostPosted: 21:13 - 12 Dec 2007    Post subject: Reply with quote
Do what Ratboy said. Start at the switch if the light terminals are clean. Your dad is probably right. Very Happy
mattjs895
PostPosted: 20:22 - 13 Dec 2007    Post subject: Reply with quote
i tested the switch today and got a voltage reading of just under 12v...any ideas what could be wrong then...
iooi
PostPosted: 21:06 - 13 Dec 2007    Post subject: Reply with quote
any suggestions
If thats with the multimeter earthed to frame, and its a good earth ( i tend to run back to battery neg terminal) then it looks like a cable is broken.
Is that at both sides of the switch, or just the battery side.
The last post was made 18 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 105.92 Kb
