| mattjs895 |
 mattjs895 Spanner Monkey
| iooi |
 iooi Super Spammer
 Posted: 18:35 - 12 Dec 2007 Post subject: |
Bulb Ok ????
Is that power to the back of the connector for the bulb, or at the switch. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| mattjs895 |
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| mattjs895 |
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 18:46 - 12 Dec 2007 Post subject: |
How do you know the bulb is OK? Are you just looking at the filament? Get a new bulb, it will take that out of the equation. If you have power and a good earth then it HAS to be the bulb, no question about it.
Z ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| mattjs895 |
| iooi |
 iooi Super Spammer
| mattjs895 |
| ZaphodBeeble |
 Posted: 18:51 - 12 Dec 2007 Post subject: |
Get a couple of wires and connect them to the battery terminals then touch them on the terminals of the bulb just briefly. It should flash. Z ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| mattjs895 |
| ZaphodBeeble |
 Posted: 18:59 - 12 Dec 2007 Post subject: |
It must be a problem with the connector that fits onto the bulb then. Are you testing the front or back of the connector? Find out which connector is the positive terminal and test for voltage. Then change the multimeter to Resistance and put one of the meter terminals in the neutral connector and one meter terminal onto the frame. The resistance should be very low or 0 ohms. That will show that you have a good supply and good earth.
| mattjs895 |
| ZaphodBeeble |
 Posted: 19:23 - 12 Dec 2007 Post subject: |
When you test for voltage are you putting the positive meter probe into the connector and the negative probe to the chassis? ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| mattjs895 |
| ZaphodBeeble |
 Posted: 19:35 - 12 Dec 2007 Post subject: |
Try it by putting the negative test probe on the chassis. Then try all the connectors with the positive probe and see what voltages you get for each. ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| mattjs895 |
| ratboy |
 ratboy Nova Slayer
| ZaphodBeeble |
 Posted: 21:13 - 12 Dec 2007 Post subject: |
Do what Ratboy said. Start at the switch if the light terminals are clean. Your dad is probably right.  ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| mattjs895 |
| iooi |
 iooi Super Spammer
The last post was made 18 years, 270 days ago. Instead of replying here, would creating a new thread be more useful? |
