clutch problem
heidi360deg20...
PostPosted: 09:29 - 09 Dec 2003    Post subject: clutch problem Reply with quote
Hey a buddy of mine has a 97 suzuki katana 600cc bike and he is having clutch problems, its real stiff to ingage and it is getting harder. he has replaced the cable and everything else but not the clutch it's self. he dosnt know much about it but i was wandering could it be hydrolic , and if so how much dot 3 should he put in? and what else should he do? any adjustments?
buh-bye..........360*
PostPosted: 10:33 - 09 Dec 2003    Post subject: Reply with quote
If it has a cable (which I think the GSX600F as its called over here has) Then its not hydraulic. Apart from that I can't help. Sorry Smile .
Sparks!
Sir Tart-a-lot
PostPosted: 00:47 - 18 Dec 2003    Post subject: Reply with quote
Erm, if you've replaced the cable, and assuming you have adjusted it appropriately then it's only really going to lead to the clutch plates/springs.
It's a very easy job to replace them and shouldn't take you much longer than an hour really.
All you need to do is, drain the oil out. Undo the clutch cover casings and you'll see the clutch assembly.
There will be around 4/5 possibly 6 bolts that you'll see on the clutch basket bit, undo these in a star sort of sequence, DON'T undo them one at a time, they hold in the clutch springs and so by undoing them bit by bit in a star pattern you won't do the clutch any damage and the springs won't pop out etc.
Once the springs are off take the center bit out and replace the friction plates then rebuild using new springs. Making sure everything goes back where you put it Wink
Then check the clutch adjustment and see if it's any better.
You can't "really" put the clutch back together incorrectly without noticing... just make sure you remember how everything went in. And take note of the clutch push rod make sure it fits back in correctly.
PostPosted: 00:48 - 18 Dec 2003    Post subject: Reply with quote
It's very possible on a VFR400 Laughing Laughing Mr. Green
Sparks!
Sir Tart-a-lot
hehe speaking from experience? lol
PostPosted: 00:51 - 18 Dec 2003    Post subject: Reply with quote
Nope. I just got to watch as Luke tried to put it back together Smile Laughing
Sparks!
Sir Tart-a-lot
PostPosted: 00:53 - 18 Dec 2003    Post subject: Reply with quote
Don't tell me Laughing , he had trouble getting the plates and corks lined up and fitting into the basket properly??
PostPosted: 22:47 - 18 Dec 2003    Post subject: Reply with quote
Also worth checking the thrust bearing in the clutch. This turned out to be shot on my XJ600 when I bought it. Only about £5 for the bearing and easy to fit.
On the XJ the gearchange became nasty and if you put the bike on the centre stand and ran the engine in gear so the back wheel was spinning, pulling the cluch meant the back wheel stopped almost instantly. Putting it in neutral and spinning the back wheel by hand and it would spin freely.
The last post was made 22 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 58.33 Kb
