2004 Blade flooding?
yambabe
PostPosted: 21:53 - 20 Dec 2007    Post subject: 2004 Blade flooding? Reply with quote
Anyone give any tips or pointers re this?
A mate of ours has a 2004 blade and is having some serious problems with it.
It would run for about 2 miles then cut out and not restart. On checking the plugs they were wet. Replacing the plugs has just led to the same thing with the new ones. This has happened a few times and the bike has usually started up again after a day ot two of not trying to get it going, but now it won't go at all.
Any ideas I could pass on to him? The bike is injection not carbs.......
Itchy
PostPosted: 22:01 - 20 Dec 2007    Post subject: Reply with quote
for a moment there I thought you had succuumbed to a blade silly me Razz
yambabe
PostPosted: 22:04 - 20 Dec 2007    Post subject: Reply with quote
LOL I very nearly did at the Welsh show this year, only for Sickpup I'd have probably made a very expensive mistake.......
Paddy Blake
You will need to get a manual.
If it's like the 2003 model.
I think there is a connector under the seat that you disconnect and short
it then turn the key on and count how many beebs it makes.
It will go trough a check and if something is wrong it will beeb X amount
of times.You will need the list to refare to.
Paddy.
PostPosted: 10:41 - 22 Dec 2007    Post subject: Reply with quote
Is it fuel injected?
Sometimes fuel injected bikes have an oxygen sensor in the exhaust to tell the ECU to adjust the fuel air mixture accordingly.
Phil_P
PostPosted: 10:46 - 23 Dec 2007    Post subject: Reply with quote
Usually fuel injected bikes have an oxygen sensor in the exhaust to tell the ECU to adjust the fuel air mixture accordingly.
Better change that to 'sometimes'. Loads of FI bikes don't run closed loop.
It is not enough to win, others must fail.
Moto Guzzi 1100 Sport Injection '96
PostPosted: 11:39 - 23 Dec 2007    Post subject: Reply with quote
My mistake, I've fixed it now.
TUG
PostPosted: 12:52 - 23 Dec 2007    Post subject: Reply with quote
2004 cbr600rr's all run rich as standard and can be leaned out a bit with a good power comander and filter and exhaust change. just a bit of info there, i dont know if the same applys for the 1000's.
Haz ER-5, innit!
The last post was made 18 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.84 - MySQL Queries: 13 - Page Size: 57.31 Kb
