| truslack |
 truslack World Chat Champion
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 18:01 - 22 Dec 2007 Post subject: |
Lube the throttle cable and linkages.
Make sure that they are not fouling causing it to jam.
Have a look at the butterfly valves in the carb to make sure that they are free and not hindered. ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| truslack |
| ms51ves3 |
 ms51ves3 Super Spammer
| Kickstart |
 Kickstart The Oracle
 Posted: 19:08 - 22 Dec 2007 Post subject: |
Suppose it is possible it is ice, but would expect running problems before it stopped the slide moving (ie, ice to stick the slide would almost certainly block the jet before it got bad enough to stop the slide returning).
I would have said the throttle cable itself as a first item. They can be worth replacing fairly early on.
Worth taking the slide out and cleaning it up. Doesn't take much grit (one tiny piece) to cause the slide to stick.
| truslack |
| Finglonga |
 Finglonga World Chat Champion
| Phil_P |
 Phil_P Trackday Trickster
| truslack |
| ms51ves3 |
| Finglonga |
| baldy |
 baldy World Chat Champion
| truslack |
| baldy |
| Kickstart |
 Posted: 00:01 - 23 Dec 2007 Post subject: |
| truslack wrote: | Thanks keith, but it has only ever happened on 2 occasions - both where it was extremely low temperatures. |
Strange. Are you certain the slide is sticking open?
| truslack wrote: | It could also be that the jet's haven't been changed when the exhaust restriction was removed, therefore the petrol is being forced through lowering the temperature? I will ask the previous owned what was done carb side. |
Nope. Likely result of that would be a seized piston.
| truslack wrote: | [edit] it is running very poorly at the moment, often requiring full choke all the time  |
Which suggests it is running stupidly lean. And the choke is a lousy way to richen the mixture. Very crude.
| truslack wrote: | How would I work out what needles to put in for a stock bike with a stock exhaust that has had the washer removed? |
Dellorto needles have the number marked on them. While you can try swapping needles around, you really need to know where you want more fuel in the throttle opening range. There are loads of different needles. Most people just move the clip to richen / weaken the mixture a bit.
| truslack |
| 1016 |
 1016 Scooby Slapper
| Kickstart |
| truslack |
| 1016 |
 1016 Scooby Slapper
| 1016 |
 1016 Scooby Slapper
| truslack |
| stinkwheel |
 Posted: 14:14 - 24 Dec 2007 Post subject: |
With regard to the needle. If you take it out, note the position of the circlip before removing it then roll the needle on a mirror. It will be immediately apparent if it is bent.
My guess would be that either the throttle valve is worn/deformed or the venturi body is slightly warped due to rough handling at some point in the past. Not a lot mind so it doesn't effect things unless it is very cold when the differing rates of contraction make it a bad fit.
Throttle cable is still the most likely candidate though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| davidlewtas16 |
 davidlewtas16 Renault 5 Driver
| truslack |
The last post was made 18 years, 311 days ago. Instead of replying here, would creating a new thread be more useful? |
