Copying Across Partitions
calum17
PostPosted: 22:15 - 23 Dec 2007    Post subject: Copying Across Partitions Reply with quote
My computer has two hard drives, but the smaller drive i have is not big enough to copy all of my files onto so that i can format my computer. I am thinking of formatting the computer by putting in a new partition first, am i then able to copy files from one partition to the other?
Hetzer
PostPosted: 11:28 - 24 Dec 2007    Post subject: Re: Copying Across Partitions Reply with quote
What? Confused Laughing
You can buy special software that'll allow you to create new partitions on the fly, but then you might as well buy a new big hard-drive (a USB external one).
calum17
PostPosted: 11:31 - 24 Dec 2007    Post subject: Reply with quote
buy - this involves money.
i just want to create a partitoin and install XP to it - as if formatting the computer. copy files from one parttion to the other and delete the original partition. can it be done? im not buying anything - i'd rather lose all of my files.
Hetzer
PostPosted: 11:45 - 24 Dec 2007    Post subject: Reply with quote
Swap your drives around, format the smaller one and put XP on that and keep the bigger one as your data drive (that also happens to have all the files you want to keep already on it).
calum17
PostPosted: 11:47 - 24 Dec 2007    Post subject: Reply with quote
using files takes much longer then, to move or open files because neither aer super high speed and the smaller one is quite a bit older so that isnt really an option either Sad
Hetzer
PostPosted: 11:50 - 24 Dec 2007    Post subject: Reply with quote
I bet you don't have a CD/DVD burner either. Laughing
calum17
PostPosted: 11:52 - 24 Dec 2007    Post subject: Reply with quote
i do, just not enough DVD's to burn everything to nor the time/patiance to sit and do it
Hetzer
PostPosted: 11:53 - 24 Dec 2007    Post subject: Reply with quote
Ok, then if you want to monkey around trying to create new partitions on an already loaded disk you'll need to read this lot:
https://support.microsoft.com/kb/309000/
Good luck. Smile
matthab
PostPosted: 21:52 - 24 Dec 2007    Post subject: Reply with quote
use norton ghost. This can copy whole HD's over to another. We use it at work regually.
2005 - 2006:Peugeot jet force 50 TDSI (sold)
2006 - Present: Yamaha YBR125 06 (extras:pilot sporty tyres and screen)
The last post was made 18 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 59.15 Kb
