1997 BMW F650 Funduro Problem
sunbear
PostPosted: 13:53 - 24 Dec 2007    Post subject: 1997 BMW F650 Funduro Problem Reply with quote
Hey fellas
I started my bike up and got the bike out of the garage on Friday when it suddenly died. I tried to start the bike straight away but there was nothing. I thought it might have been a fuse gone as the indicators, brakelight and main beam flasher still work. But I am getting no starter noises or headlight at all. Just nothing.
I have checked all the fuses, battery is charged up, there is no obvious kinks or damage to any cables (i have the tank and stuff off at the minute), and the right hand switch gear (which houses the starter button and the headlight switch) seems fine inside. All earth points are in a good clean condition.
Im stuck here, any help would be appreciated.
Thanks Thumbs Up
Bikes had : BMW F650, suzuki tr50, gt125, SV400, GSXR600 SRAD. Honda CBR900RRP, CBR600FX, CBR1000F, VT600, Transalp 600, mtx125, nsr125r, CB500T, Yamaha fy50, tzr125, tdr125, XV535, Diversion 600, Fazer 600, TDM850 MK1 & MK2, Majesty 400, XV 1100. Cagiva mito evolution, Aprilia rs125, Piaggio x9 125. DNA 125 . Suzuki Bandit 600, GZ125 Marauder, RF600 , RF900RS2, Kawasaki ZZR400, ZX6R Ninja, ZZR600 . Ducati 750 Sport . Triumph Tiger 955i. CURRENT : 2004 Kawasaki Z750 and LOVIN IT !
iooi
PostPosted: 14:00 - 24 Dec 2007    Post subject: Reply with quote
I guess the best check is, is there any power to the starter switch ?
Start there and meter back.
Not the obivious, kill switch, or side stand switch.
What voltage do you get on the battery ?
PostPosted: 14:21 - 24 Dec 2007    Post subject: Reply with quote
Side stand switch can and does go on these.
Make sure you got ALL the fuses. I seem to recall seeing a variety of nippy micro-fuses outwith the boundries of the fuebox when I looked at my mates F650.
sunbear
PostPosted: 14:37 - 24 Dec 2007    Post subject: Reply with quote
Thanks for that. If it was the sidestand switch though, wouldnt the headlight still work ?
PostPosted: 14:42 - 24 Dec 2007    Post subject: Reply with quote
Probably. But motorcycle wiring is a highle erratic science. I couldn't tell you on a German bike. People do wierd things when they are designing looms.
On the face of it there isn't really anything that should deactivate both the starter AND the headlamp but nothing else. Apparently there is.
Tiff
PostPosted: 21:52 - 24 Dec 2007    Post subject: Reply with quote
I had an Aprillia Pegaso 650,which did exactly the same,and its basically the same bike.Turned out to be the fuse holder-2 fused on the left hand side,under the seat. The fuses were fine,but the connector had corroded,and caused the same problems as yours.Worth a shot.Just switch on the ignition and lights,and give everything a wiggle and a twist.
1996 Kawasaki GPZ1100s,1996 VFR750,1980 BMW R80,1982 Kwak Z250B,1992 ZZR1100C,1996 BMW K1100LT,1994 Kwak ZZR600E,1993 BMW R1100RS,1992 ZZR 600D,1988 BMW K100LT,1998 Aprilia Pegaso 650,1994 Suzuki RF900,1991 Yamaha XJ600, 1988 Honda Dominator,1992 Kwak KMX125,1987 Yamaha RD50MX,1984 Honda MBX50.1984 Honda Superdream 125
sunbear
PostPosted: 08:31 - 26 Dec 2007    Post subject: Reply with quote
Thanks will try that . Much appreciated Thumbs Up
Finglonga
PostPosted: 14:49 - 26 Dec 2007    Post subject: Reply with quote
Give the loom around the headstock a wiggle with the ignition on to see if anything happens. BMW have a tendency to develop an intermittent fault when one of the wires breaks in the sheath. Usually happens with the 1150's but not unknown on other BM's.
If it it its a ball ache to try and find the wire to re connect the broken link. Shocked
Andy Sez....
F.Y.Y.F.F.
sunbear
PostPosted: 21:41 - 28 Dec 2007    Post subject: Reply with quote
Hey, sorted out the problem...... a connection had come undone hidden away just behind the headlight in the fairing. Thanks for all the help Thumbs Up
The last post was made 18 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.59 - MySQL Queries: 13 - Page Size: 62.31 Kb
