Knock Knock Knocking :(
Louise
PostPosted: 17:13 - 28 Dec 2007    Post subject: Knock Knock Knocking :( Reply with quote
Ive just noticed when I pull away there is a 'Knock' just a single one. Been doing it for a few days. Today on the way home it knocked 3 times, as I was pulling away.
Only thing I can think of is at the tart of the month I had a bigger sized tire put on the bike and the forks dropped to being the lights back down to pass the mot. Would this cause the knock, I cant remember if it made that noise back then.
Just hoping its still safe to ride Confused
2t-Screamer
PostPosted: 17:58 - 28 Dec 2007    Post subject: Re: Knock Knock Knocking :( Reply with quote
thats happened to me before and it was a knackered big end bearing (i could feel the knocking through the footpegs), im not saying it is that but you don't want to be riding the bike if it is.
Louise wrote:
tart of the month
who's that then Laughing
visit Collective Knowledge
st3v3
PostPosted: 18:03 - 28 Dec 2007    Post subject: Reply with quote
As above, although ANY fractionth of a millimeter movement in that bit could cause a knock(ing), get it checked out ASAP, would you want it to possibly get you stranded say.. 40 miles from home as a dead weight with recovery fee's etc?
Louise
PostPosted: 19:08 - 28 Dec 2007    Post subject: Reply with quote
Laughing Im so tired I didnt notice
I got all day tommorow at work, Monday so Wed morn or friday is only time I can get it looked at.
Is it a big job (If it is the big end) Rough estimate of the job ?
Ifs its too much I wont bother, I really dont want to spend anymore on this bike as im not keeping it.
st3v3
PostPosted: 19:10 - 28 Dec 2007    Post subject: Reply with quote
If it's the big end it's one of the biggest jobs you could have. Laughing
Next owner would most likely endure the fix in that case, don't envy them. Sad
mr jamez
PostPosted: 19:18 - 28 Dec 2007    Post subject: Reply with quote
SV650?
Estimate? That'll be a new lump off ebay...
As its just one knock when you pull away, I'd hazard a guess at something else. Possibly the chain hitting something if it isn't tensioned correctly or the runners are missing/damaged. I think it needs more poking.
Ichy
PostPosted: 19:24 - 28 Dec 2007    Post subject: Reply with quote
Big end bearing make a constant knocking sound, getting louder as they get worse.
Can you safely lift the front wheel off the ground? if you can then give the front end a good inspection, pull it about a bit see if anything is loose. Loose forks, wheels or headstock bearing can make knocking sounds as can loose cables hitting other bits.
Spin the front wheel, put the brakes on a few times and do the same, spin the wheel backwards and forwards. Brake pads can move around in the calliper and make a knocking sound.
Ariel Badger
PostPosted: 20:12 - 28 Dec 2007    Post subject: Reply with quote
If you ever have a big end go there is no mistaking it. The entire bike feels like it is being hit with big hammers by angry chimps. Try to isolate the noise, with engine cut lift the back end and turn the wheel if you can not locate it at the back do the same at the front end. Could be, chain, brake, bearing, speedo drive, clutch etc.
Nb
PostPosted: 23:50 - 28 Dec 2007    Post subject: Reply with quote
Get your fork bolts checked again, also make sure your chain is ok.
PostPosted: 01:48 - 29 Dec 2007    Post subject: Reply with quote
Have you checked your chain tension?
Walloper
PostPosted: 02:19 - 29 Dec 2007    Post subject: Reply with quote
Big end 'knock' will be more noticable when you increase the engine RPM in neutral. As you let go the throttle you will hear any worn 'Big End' clattering. Not so much of a clunk at first more like knock.
(Onomatopea in such matters though is of no real significance.)
Sure fire way to tell easily is to:
1) Buy a new engine oil filter.
2) Drop the oil from the sump into a clean container. (So you can re-fill after.)
3) Remove the oil filter.
4) Install new filter and re-fill with oil (IF THE OIL IS GOOD AND NOT FULL OF METAL).
5) ***WARNING*** SHARP EDGES, PAY ATTENTION TO YOUR FINGERS. BETTER TO WEAR HEAVY GLOVES. Hacksaw the old filter open and rip some of the paper filter element out.
6) Open the pleats and look for bright metal particles.
If the 'Big End' is gubbed then it will show in the filter.
Good luck.
Phuquedtifano what the other cause of the knock could be...
smegballs
PostPosted: 19:55 - 29 Dec 2007    Post subject: Reply with quote
i had a knocking when i pulled off on my Turned out that the chain was way loose and throwing itself around everywhere. Re-did chain tension and bike was right as rain, for thew next 200 miles....
PostPosted: 20:01 - 29 Dec 2007    Post subject: Reply with quote
Can you say where the knock feels like it is coming from. How harsh a knock it is?
Loads of things can give what feels like a knock. Tight spot in a chain that has been adjusted too tightly for example, but likely to be felt most through the footrests.
Whosthedaddy
PostPosted: 21:10 - 29 Dec 2007    Post subject: Reply with quote
Turn on bike
Get a long screwdriver, phillips or flat head your choice
Put the screwdriver to your temple
Put the screwdriver onto various engine casings to isolate the 'knocking' (its a cheap version of a stethoscope).
My ZX has a small rattle at slow speeds, I know its not from the engine so check the wheels and brake pads for any loose play.
Louise
PostPosted: 14:03 - 30 Dec 2007    Post subject: Reply with quote
I will check out all of above today.
Oil issue is, Ive put some in but I cant see any in the window. I havnt a center stand so I double check by having someone else there. Still no Oil is showing, Ive put in over half a bottle.
The Knock seems to be from the front end.
Will report back later Smile
Damon
PostPosted: 14:11 - 30 Dec 2007    Post subject: Reply with quote
could it be the bearing in the headstock? lift the front and see if there is any play in the front end. TBH i do not think its the big end bearing.
Checked pads in calipers, squirrels in radiators etc?
Ichy
PostPosted: 14:56 - 30 Dec 2007    Post subject: Reply with quote
Lean the bike right over to the left while watching the sight glass. Then slowly lift it back up. Sometimes with new oil its hard to see especially if its filled all the way up.
Louise
PostPosted: 10:10 - 04 Jan 2008    Post subject: Reply with quote
Still not had time to check it. Once I get to work today I will get someone to lean the bike over.
Kickstart - the Knock isnt really harsh but, its after I pull away (Not from standstill) if that makes sence.
Another problem, not sure if its from the same source or not, just comming home it started to back fire from the can, then I could hear it pop underneath and didnt really want to pull in 2nd 3rd gear. From a quick look last night everything is bolted on tightly.
I really dont want this thing to seize on me, and I cant see it should as I have put oil in there How will I know if its about to seize? Or dont you Confused
Barry_M2
PostPosted: 10:38 - 04 Jan 2008    Post subject: Reply with quote
Could be a loose exhaust bracket (at the head) that's rattling, which would in turn cause a leak and would explain the slight backfire.
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
Keir
PostPosted: 10:48 - 04 Jan 2008    Post subject: Reply with quote
clutch ok? could worn clutch springs make the clunk when you pull away?
Current : '08 Yamaha FZ1s
BFG
PostPosted: 12:20 - 04 Jan 2008    Post subject: Re: Knock Knock Knocking :( Reply with quote
Ahem Wink
Louise wrote:
pass the mot
The MOT should have caught any suspension / bearing / drive train problems significant enough to cause a knocking noise. Not guaranteed mind, but certainly more reliable than a "poke about".
This leaves the engine. It could be engine knock, is not as serious as big end failure. Are you running on standard or super petrol? Does it behave differently on each?
PostPosted: 12:52 - 04 Jan 2008    Post subject: Reply with quote
Do you mean that you cannot trigger the noise when at a standstill (ie, revving the engine, holding braking and pushing backwards and forwards, etc), but that you get the noise just after you pull away?
What may be worthwhile is having someone else ride the bike and see if they can spot it, and more so see if you can spot where the noise is coming from as they pull away.
Louise
PostPosted: 00:22 - 06 Jan 2008    Post subject: Reply with quote
No noise at all while standing still - I was watching the Speedo and bang on 10mph came the one single knock.
I got someone else to ride it, he said he heard nothing, So I got back on the bike - and I didnt hear nothing, but afterwork soon as I left 'Knock'
We have both said the chain could be causing it as it is a bit loose.
Ive just not had time to do anything.
We got the bike into a tripod, wheel span ok, no loose wires or anything w could see.
Except he said something about new brakes could make a noise Confused
Just standard for now, not noticed any different when I first got the bike (Old owner used both) But Im sure my carbs are really out at the moment, so I wouldnt be able to tell.
Will go over the whole exhaust, it happends every now and then - Going to work fine, riding home it would just drop revs, chug and pop underneath, or back fire from the can.
The only other thing as I said above, I had a 120/60 on the front and had a 120/70 put on instead - the guy said to drop the forks by 9mm to lower the front. Im sure I didnt hear the noise right away but then again I had not ridden for 2 months so I was off.
Could that cause something?
Just starting to hack me off, problem after problem at the moment Thumbs Down
PostPosted: 00:52 - 06 Jan 2008    Post subject: Reply with quote
Chains can do when semi knackered. A tight spot can result in a "crack" noise. Sometimes seems to only happen when cold. As such worth checking when you first use the bike, not just after a journey.
Also remember that sitting on the bike tightens the chain a bit.
Brakes can make noises. Cast iron disks can have the pads stick to them, but this would only make a noise when they first unstuck (probably from being parked over night) and I don't think you have a cast iron disk.
Pads can make a quite rattle in the caliper (but would happen all the time and is very quiet), and the caliper can make a click if its mounts are worn (sliding calipers normally).
Sorry, other giving you a bit more info on one possibility I haven't really answered anything there.
The last post was made 18 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.40 Sec - Server Load: 10.85 - MySQL Queries: 13 - Page Size: 134.92 Kb
