Help, total noob here..
Eddie Hitler
PostPosted: 11:43 - 02 Jan 2008    Post subject: Help, total noob here.. Reply with quote
And i want to give my bike an oil change.
I have a very BASIC idea of how to do it, i just need some tips on what not to do, so i make as little mistakes as possible.
Im also aware i dont have a torque wrench.. is it really needed when doing the sump bolt back up?
Also my tool range is lacking alot, im off to Norwich in an hour so basic tools i need to buy can be done then.
Thankyou!
Bishbash
PostPosted: 11:49 - 02 Jan 2008    Post subject: Reply with quote
An oil change is pretty straight forward as you can imagine. The main "No No" is the sump bolt. As you said you dont have a torque wrench, so dont overtighten it. Are you changing the oil filter too? It is advisable and ideal opportunity to do it.
BB
Eddie Hitler
PostPosted: 11:51 - 02 Jan 2008    Post subject: Reply with quote
Well i was thinking that too, if its ideal to buy a torque wrench and it makes my life a bit easier then im all up for purchasing one, ideal investment anyway.
Finglonga
PostPosted: 11:55 - 02 Jan 2008    Post subject: Reply with quote
You don't need a torque wrench but it is advisable. As long as you just pinch the bolt up and then a 1/4 more at most and not give it all you have got. Keep an eye on it just in case it starts leaking.
As above if the bike has a filter change that also otherwise your only doing half a job.
Andy Sez....
F.Y.Y.F.F.
Eddie Hitler
PostPosted: 12:00 - 02 Jan 2008    Post subject: Reply with quote
Okay, its an FMX650. I seriously have no idea on bolt sizes and all that.
Its the old Domi engine if that helps.
hmmmnz
PostPosted: 12:04 - 02 Jan 2008    Post subject: Reply with quote
as above really.
i have never used a torque wrench in my life,
just dont be over zealous, its better to have it a bit too loose and get a wee leak that you can just give it a little tighten up later on,
than over tighten, and get a leak any way because you have fuct the thread,
also only hand tighten the oil filter and rub a little oil on the rubber gasket,
or you'll end up with this the next time you have to do a filter change
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF1138Small.jpg
mmm nice filter Very Happy
the humans are dead
I kick arse for the lord
Bishbash
PostPosted: 15:21 - 02 Jan 2008    Post subject: Reply with quote
Shocked Shocked Shocked ..OMG what on gods green earth did you do to that????
BB
PostPosted: 15:52 - 02 Jan 2008    Post subject: Reply with quote
Run the engine briefly to warm the oil up - this will help with draining. Remove the sump bolt, drain the oil out, fit a new sump-bolt washer, re-fit bolt taking cae not to over-tighten it. This is just plugging a hole not supporting it's own weight. As a guide, if you have quite strong hands it needs to be no more than you can tighten it by holding a ratchet near the head and turning your wrist, then a small tug on the handle to nip it up. The new washer will deform to provide an oil-tight seal and stop the bolt coming undone. Check it after you've ridden the bike the 1st time.
hmmmnz
PostPosted: 16:05 - 02 Jan 2008    Post subject: Reply with quote
BB
well i couldn't undo it with either my hand or my oil filter tool, so i resorted to the screwdriver through the filter trick, which still didn't work, so i then preceded to tear the filter to pieces so i could get to the little holes and use a screw driver and hammer to turn the filter,
i had to remove the exhaust system to do it, what should have been a 10min oil change turned into a 3 hour mission, just because the last person to do an oil change didn't oil the filters rubber seal, and over tightened it.
fun times Very Happy
the humans are dead
the grim reaper
PostPosted: 16:19 - 02 Jan 2008    Post subject: Reply with quote
One other handy tip is to fill the filter with fresh oil. The oil pump tends to draw oil through the filter, if the filter is empty then the oil pump will be sucking on nothing and that does not do the pump any good.
Grim
Finglonga
PostPosted: 18:10 - 02 Jan 2008    Post subject: Reply with quote
Also put a smear of oil on the thread and if fitted rubber sealing ring of the filter so it is easier to remove next time. Wink
Also engine should be at operating temperature not just warm so the oil drains fully from the top end.
Andy Sez....
F.Y.Y.F.F.
Ariel Badger
PostPosted: 18:19 - 02 Jan 2008    Post subject: Reply with quote
Do not forget to fill it back up (it happens). Mr. Green
beans
PostPosted: 18:21 - 02 Jan 2008    Post subject: Reply with quote
If your still stuck and anywhere near Lowestoft drop me a PM. Thumbs Up
Yamaha FS1E- Suzuki RG 125 - Honda CB-1- Ducati Monster - Kawasaki ZX6-R F1- Kawasaki ZX6-R G1- 2003 Yamaha R6
Eddie Hitler
PostPosted: 18:50 - 02 Jan 2008    Post subject: Reply with quote
Beans, your bike didnt break down a few days ago did it?
Thanks for replies Thumbs Up getting the bits on friday and then giving it a go Laughing Will update then!
beans
PostPosted: 18:54 - 02 Jan 2008    Post subject: Reply with quote
Nah it's tucked away in the garage till the 19th when I part ex it in for the newun!
Eddie Hitler
PostPosted: 18:57 - 02 Jan 2008    Post subject: Reply with quote
Ahh fair enough lol, I stopped to offer my mobile to some guy on a Kawasaki ZX6, im based in south Norwich so not too far from you Thumbs Up Ill see how i get on Friday Laughing
funmonkee
PostPosted: 19:30 - 02 Jan 2008    Post subject: Reply with quote
Are you sure Logan Question
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
PostPosted: 19:38 - 02 Jan 2008    Post subject: Reply with quote
And don't be tempted to fit the plug finger-tight so you can stop it dripping whilst you empty the oil-pan with a view to tightening it up later. Many people have done that and regretted it too.
In the same way, remember to put the sump bolt in before filling it back up (it happens). Mr. Green
The last post was made 18 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 104.81 Kb
