| craigwrf |
 craigwrf L Plate Warrior
 Posted: 16:48 - 04 Jan 2008 Post subject: pressure release valve |
hay every1 iv got a yam wrf400, it over heated releasein the coolant out of the release valve. the only problem now is that there is still coolant coming out of the release hole. can anyone help with my problem thanks  |
 Posted: 17:54 - 04 Jan 2008 Post subject: |
Overheated, or has the head gasket blown causing the coolant to become pressurised with exhaust gas?
Squeeze your rubber radiator hoses as it is spitting coolant, if they are rock hard, you are probably looking at a blown head gasket ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| craigwrf |
| finpos |
 finpos World Chat Champion
| Finglonga |
 Finglonga World Chat Champion
 Posted: 21:34 - 08 Jan 2008 Post subject: |
| craigwrf |
 Posted: 17:39 - 09 Jan 2008 Post subject: |
its the hole in the right hand side casing and it sits just behind the water pump but its not part of the water pump itself. i will get a new radiator cap and c if that helps the problem thanks for ya help  |
| finpos |
| Stelmer |
 Stelmer World Chat Champion
| craigwrf |
| finpos |
 Posted: 21:48 - 10 Jan 2008 Post subject: |
Most water pumps are shaft driven from the engine. On the shaft there are two seals - one to keep the oil in the engine and the other to keep the water in the pump. There's a gap between the two seals, and in that gap there is generally a drain hole. Then, if either or both of those seals go, the fluid dribbles out of the drain (onto your back tyre ) instead of building up and contaminating the other side.
Usually what happens is the shaft gets worn/pitted, both seals go and you get an emulsion dripping out of the hole. It'll drip constantly but more so with the engine running.
Don't know which copper washer you mean, sorry!
f. |
| craigwrf |
The last post was made 18 years, 28 days ago. Instead of replying here, would creating a new thread be more useful? |
