pressure release valve
craigwrf
PostPosted: 16:48 - 04 Jan 2008    Post subject: pressure release valve Reply with quote
hay every1 iv got a yam wrf400, it over heated releasein the coolant out of the release valve. the only problem now is that there is still coolant coming out of the release hole. can anyone help with my problem thanks Confused
PostPosted: 17:54 - 04 Jan 2008    Post subject: Reply with quote
Overheated, or has the head gasket blown causing the coolant to become pressurised with exhaust gas?
Squeeze your rubber radiator hoses as it is spitting coolant, if they are rock hard, you are probably looking at a blown head gasket
craigwrf
PostPosted: 21:00 - 08 Jan 2008    Post subject: Reply with quote
iv checked the coolant pipes when the bikes runnin and when its turned off there fairly soft. iv had a few ppl tel me to change the thermostat but i cant find the bloody thing iv had a look in my manual and on the manuals from here but still no luck even phoned a yam company up n thay couldn even find it PLEASE PLEASE HELP
finpos
PostPosted: 21:13 - 08 Jan 2008    Post subject: Reply with quote
Changing the thermostat is the last bastion of those who don't know what the hell is wrong with their engine. Which hole exactly is water coming out of? The three I can think of would be on the water pump, on the neck of the radiator next to the radiator cap and in the expansion tank.
If it's loosing fluid without overheating it will normally be the radiator cap if you are very lucky or what stinkwheel said if you're not.
f.
Finglonga
PostPosted: 21:34 - 08 Jan 2008    Post subject: Reply with quote
https://upload.wikimedia.org/wikipedia/commons/thumb/d/d5/No_sign.svg/600px-No_sign.svg.pnghttps://psydok.sulb.uni-saarland.de/volltexte/2004/117/html/psycyber/palgraphics/texttalk.gif
Andy Sez....
F.Y.Y.F.F.
craigwrf
PostPosted: 17:39 - 09 Jan 2008    Post subject: Reply with quote
its the hole in the right hand side casing and it sits just behind the water pump but its not part of the water pump itself. i will get a new radiator cap and c if that helps the problem thanks for ya help Cool
finpos
PostPosted: 20:27 - 09 Jan 2008    Post subject: Reply with quote
Sounds like your water pump seal has gone - they normally have a bleed/drain to stop the engine casing filling with steaming hot water and destroying the bearings. Don't think a rad caps going to help!
f.
Stelmer
PostPosted: 21:41 - 09 Jan 2008    Post subject: Reply with quote
Thermostat will be somewhere before the hose going to the top of the radiator in the engine.
Easy way of testing it is to keep your hand on the top hose and feel it warm up fairly quickly, after the engine has warmed the water jacket up first.
Check the cooling fan works as well. I shorted the wires going to the switch together to test it before i ran the engine to see if the switch worked.
craigwrf
PostPosted: 19:24 - 10 Jan 2008    Post subject: Reply with quote
i will check it at the weekend as by the time i get home its to dark.
would that b the seal behind the copper washer and the water pump??
thanks for al ya help guys
finpos
PostPosted: 21:48 - 10 Jan 2008    Post subject: Reply with quote
Most water pumps are shaft driven from the engine. On the shaft there are two seals - one to keep the oil in the engine and the other to keep the water in the pump. There's a gap between the two seals, and in that gap there is generally a drain hole. Then, if either or both of those seals go, the fluid dribbles out of the drain (onto your back tyre Smile ) instead of building up and contaminating the other side.
Usually what happens is the shaft gets worn/pitted, both seals go and you get an emulsion dripping out of the hole. It'll drip constantly but more so with the engine running.
Don't know which copper washer you mean, sorry!
f.
craigwrf
PostPosted: 16:28 - 11 Jan 2008    Post subject: Reply with quote
i think i know which seals your talkin about il take the bike to bits tomorrow and sunday and see wht i can do thanks for all your help much appreciated cheers
The last post was made 18 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 66.1 Kb
